hi
when i set a font, it's color and position for a sub file in textSub, it works fine if I do a 1 pass encoding
but for some reason if i do a multipass encoding, the settings are reset and the subtitles are present on the resulting vid, but with default position, font, size, ect...
i guess i'm doing something wrong, but i can't seem to find what
anyone can help?
thanks![]()
Haven't done that with subs, but I suspect you would have to add the subs on the second pass. The first pass just measures the bitrate needed for the scenes and may mess up the subs settings.
Someone with more sub experience with VD can probably give you a better answer. -
Thanks for your answer, I wasn't aware that's what a 1rst pass does
I use to make 3 passes encoding in order to limit the quality loss to a minimum
I will try this (setting the subs only for pass 2 and pass 3)
Unfortunately, I have no video to encode atm, but tomorrow or the day after at most I should be able to test the method
Of course, I'll keep you informed -
I found the time to make a test: it didn't work, the subs are on the video, but with default settings
TextSub horror!
By YiuKorochko in forum SubtitleReplies: 2Last Post: 1st Aug 2011, 16:38 -
Font problem with TextSub 2.23
By Keeyu in forum EditingReplies: 0Last Post: 8th Jan 2011, 20:42 -
TextSub in Avisynth.
By Sarlula in forum SubtitleReplies: 3Last Post: 18th Dec 2009, 18:24 -
What exactly is the problem Virtualdub has with Divx multipass?
By Onceler2 in forum Video ConversionReplies: 14Last Post: 20th Aug 2008, 18:00 -
problem with accented letters using textsub in Virtual dub Mod
By Deathknight in forum SubtitleReplies: 2Last Post: 29th Apr 2008, 21:47
