Hi all, I am in need for help quite urgently so please hear me out.
I have four 30 second clips to put on the same DVD, just call them A,B,C and D.
I want the disc to start with A, which it should Loop itself, until I press jump to next, when it will jump to B.
Then it's the same with B, I want it to loop itself, until I press jump back/jump to next, which will lead it to A or C respectively.
Basically I want all four clips to do that, I currently have DVD-lab pro, but I have no idea how to achieve it, tried the multi-PGC title route but have no luck.
so can it be done in dvd-lab, or any other software?
any help will be much appreciated.
Yes, it's possible. Basically you want to add a cell command to the last cell of each potentially looping segment. For example, if all looped parts are single-cell, the command type would be 'Link Top Cell' (in terms of DVDRemake program). Such a command is executed in the end of a cell playback and re-starts that cell. When you skip to next chapter, the command is ignored. If the pieces have more than one cell, you can use Link Cell# (first cell # in the chapter) or Link Program # commands, depending on how PGC is organized.
This editing can also be applied to any chaptered (=having multiple cells) video in DVDLab's VM command editor or PGCEdit (I personally prefer DVDRemake). -
Much thanks, due to time constraint I have used a simple workaround with the menus, basically I made some invisible buttons to cheat around it, but I will look into your solution more indepth later.
New Tool: Combine TV MKV Episodes auto creating chapters
By kingfetty in forum Video ConversionReplies: 1Last Post: 21st Feb 2014, 13:15 -
Auto-chapters in Adobe Encore CS5?
By Benhermies in forum Newbie / General discussionsReplies: 1Last Post: 20th Jul 2011, 08:30 -
Problem making chapters with RDR-HX780 Sony HDD recorder
By 1234567 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Feb 2010, 10:56 -
Making movies with chapters
By dw1 in forum Newbie / General discussionsReplies: 3Last Post: 16th Jun 2008, 07:53 -
How do I stop a DVD from repeating the program?
By billlaux in forum Newbie / General discussionsReplies: 6Last Post: 23rd Jan 2008, 20:51
