    May 2003
    Israel
    Hi,
    I have downloaded DVD format (min-DVD) form camcoder (10 minutes length of the original film): I uploaded this file into the Pinnacle Studio 14 and edited the film: Afterwards, I have exported the file into MPG4 format. Afetr watching the moview on the TV / PC, after about 1 minute the audio and video are lost the syncronization (Video ahead of audio).
    While view the film from the Pinnacle timeline - everything looks OK.
    What should be the problem?
    Regards,
    Uriel
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Unfortunately I personally believe the answer is in prep-work BEFORE loading into Pinnacle.....like converting the miniDVD material to straight MPEG first.
    May 2003
    Israel
    Thanks: How can I convert the DVD into MPG4? Is there a simple (and freeware)
    program for this?
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    program for this?
    MPEG2(DVD) or MPEG4?
    May 2003
    Israel
    I would need from DVD (mini DVD) to MPEG4.
    Thanks.
  6. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Just rip the video from the DVD with VOB2MPEG ...that will give you one giant lump of video. That should end your problems in your editing program. I'm guessing you need to do some editing before you go to MPEG4.
