Can anyone tell me about a sodftware wich can add text...In all my videos...Without loss of quality and increase in size? or can anyone tell me the video and audio properties to make a 700MB AVI and 400MKV...???
1. You cannot add text without re-encoding.
2. Re-encoding always risks quality loss
3. Re-encoding with a lossy codec guarantees quality loss
4. You can get the same output size by encoding with the same bitrate as the source
5. Mediainfo can tell you what the source bitrate is
6. You don't have to re-encode audio just because you change the video
7. Avisynth can be used to add you text, however you will have to find an encoder that handles avisynth input (most good ones can)
8. If you want your output files to have a different filesize to the source you will have to use a bitrate calculator to determine what the correct numbers should be
9. you can find bitrate calculators in the Tools section (link to your left)Read my blog here.
You can add a subtitle, as say an SRT file.
If it has the same name as the video (with SRT extension) then most media players will display it automatically.
Subtitles can be embedded in an MKV.
If however you want to brand some video with a logo that can't be turned off, then you have to reencode. -
There are no problems - only chances to excel.
-- Unknown
MKV to AVI without quality loss - for watching on DVD player
By mr-scarface in forum Video ConversionReplies: 19Last Post: 17th Apr 2013, 17:59 -
Converting Multiple Audio Track MKV's to avi without Quality loss
By OrtegaSeason in forum Video ConversionReplies: 4Last Post: 6th Feb 2011, 08:09 -
What is the best/simplest .mkv to .avi (xvid) convertor? (no quality loss)
By loveranger in forum Video ConversionReplies: 11Last Post: 21st Jan 2010, 23:07 -
How to Convert MKV Files into DVD Without No Loss Quality?
By devilcoelhodog in forum Newbie / General discussionsReplies: 1Last Post: 8th Dec 2009, 18:55 -
By Markomaani in forum Video ConversionReplies: 10Last Post: 15th May 2009, 10:51
