Is there a way to edit AVCHD in Vegas 10 pro and save it to a format that can be uploaded to youtube (IE: not a lossless format) without much quality loss? Thus far everything I've tried has resulted in a very noticeable loss in quality. I realize that youtube quality is very low anyway, but the quality of the file you input seems to matter a lot, as uploading raw .mts files from my camera (Canon HG20) results in the best quality I've seen on Youtube, while uploading anything I've reencoded from them suffers a serious quality loss.
use the sony avc encoder and a template matching your source/or change one to match it, go to options and change the bitrate to as high as it goes. the internet templates are usually a good place to start. make sure the project render quality is set to best.
I tried that, the highest the sony avc codec goes for bitrate is 16mbps and there's a very noticeable loss in quality.
Taking already anamorphic video and saving it that way in Sony Vegas
By apollo1980 in forum EditingReplies: 4Last Post: 2nd Jan 2011, 19:51 -
Saving original HD footage (AVCHD) which file to keep?
By Lilygrace in forum Newbie / General discussionsReplies: 3Last Post: 24th Sep 2010, 17:01 -
From Vegas to Final Cut Pro - How to export without (much) quality loss
By BovineofWar in forum MacReplies: 18Last Post: 28th Apr 2010, 21:04 -
Vegas 8 - Saving presets somehow?
By sdsumike619 in forum Authoring (DVD)Replies: 1Last Post: 20th Oct 2008, 00:11 -
Editing Canon HF11 30p/24Mbps AVCHD footage With VideoStudio 11.5+ HELP!
By tat2jr1 in forum Video ConversionReplies: 4Last Post: 25th Sep 2008, 11:25
