What is the resolution of DVD widescreen?
It will be the same as any other DVD: 720x480/576. The aspect ratio is determined by the display aspect ratio field, which is set in the MPEG header, not the resolution.
Same as regular DVD, if you want to create a VCD or SVCD as Wide Screen, then simply do the appropriate changes in TMPGEnc.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
which resolution for 32" widescreen?
By iancur in forum Video ConversionReplies: 1Last Post: 2nd Feb 2011, 13:48 -
42 inch plasma widescreen (16x9 hdtv has native resolution 1024 x 768 (4x3)
By sbt5 in forum DVB / IPTVReplies: 15Last Post: 4th Aug 2009, 21:59 -
vertical resolution of anamorphic widescreen?
By Sean_ve99 in forum Video ConversionReplies: 12Last Post: 7th Jan 2009, 11:41 -
PLASMA resolution..1024x1080 (or 1024x768) ..surely isnt widescreen?
By snadge in forum DVB / IPTVReplies: 6Last Post: 2nd Sep 2007, 11:24 -
My widescreen slashes resolution
By seragx99 in forum Video ConversionReplies: 1Last Post: 5th Jul 2007, 02:38
