    Jan 2011
    Québec, Canada
    Hi all,
    I want to digitalize a lot of VHS into DVD, and I'm wondering what is the best Player and TV Card to do this.
    Does the VHS Player makes a difference in quality? If so, what should I look for when buying one?
    Second question, my Gateway LX-6810 came with a tv tuner card (can't find exact model in spec. http://www.gateway.com/systems/product/529668232.php). Will a Hauppage 2250 make a difference? Any other suggestion for TV card?
    I don't really have a price range for this stuff. I just want the best quality possible in a reasonable price range (less than 1000$). I'm ready to pay more only if it makes a real visible difference.
    Thanks for your advice
    Max
    Oct 2010
    England
    Originally Posted by gejlvem View Post
    Hi all,
    Your question pops up regularly on here, so most of what you're asking has already been answered. This thread for example has a lot of useful info:
    https://forum.videohelp.com/threads/330494-VHS-to-PC-capture
    I couldn't easily find what TV tuner your computer has, but it may be suitable for your needs.
