I've never been able to make a satisfactory backup of my Star Trek TOS disks. They contain two versions of each episode. I looked at the structure with BDinfo and unlike other seamless branched disks that have separate playlists for each version the Star Trek disks have only one playlist for each episode. The alternate version of the episode seems to be identified with the suffix (1) within the playlist. I always get an audible "bump" in the audio at the transition between versions.
Is there a way to eliminate the seamless branching?
When you say "backup" do you mean a BDRB re-encode?
If so, then it doesn't work for me either on seamless branched discs, and discs with PiP can be troublesome too. (For those I extract titlesets with Clown_BD.) Had to do that with The Pacific series. Rather than go to any more trouble, I just joined episodes and remuxed with tsMuxer. Supposedly it's possible to replace titles with multiAVCHD and keep original menus. Definitely doable with BDEdit.
The structure you describe is something I don't recall having ever seen.Pull! Bang! Darn!
Which DVD authoring application is good at seamless branching?
By AnitaPeterson in forum Authoring (DVD)Replies: 4Last Post: 6th Apr 2009, 21:03 -
Seamless Branching
By Mirkoschieder in forum MacReplies: 2Last Post: 6th Apr 2009, 10:58 -
Should Sony change the name to "blue-ray" instead of blu-ray
By yoda313 in forum Off topicReplies: 11Last Post: 17th Feb 2009, 13:52 -
Which Software for Seamless Branching?
By -horn- in forum Authoring (Blu-ray)Replies: 3Last Post: 15th Jul 2008, 11:15 -
blue ray blue rot
By NICEBUD in forum Latest Video NewsReplies: 5Last Post: 21st Jun 2007, 12:01
