Im trying to figure out what im doing wrong here, Im muxing a few thousand ts (264/ACC > AAC) files to mp4 which works but in explorer and properties the files duration is always double the length 3:37:21 and this is showing up in directshow media players.
my command is,
"MP4Box.exe" -add "Z:\New Movies\TS\A.264:fps=25.000" -add "Z:\New Movies\TS\A.aac#1" -new "Z:\New Movies\TS\A.mp4"
And the file information is
yet every single file has double the duration it should have in all directshow players.General
Complete name : Z:\New Movies\MP4\Alien vs Predator.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 2.57 GiB
Duration : 1h 48mn
Overall bit rate : 3 379 Kbps
Encoded date : UTC 2011-01-12 21:10:14
Tagged date : UTC 2011-01-12 21:10:14
Video
Format : AVC
Codec ID : avc1
Duration : 1h 48mn
Bit rate mode : Variable
Bit rate : 2 928 Kbps
Maximum bit rate : 11.8 Mbps
Width : 1 280 pixels
Height : 544 pixels
Display aspect ratio : 2.35:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Bits/(Pixel*Frame) : 0.175
Stream size : 2.22 GiB (87%)
Tagged date : UTC 2011-01-12 21:18:04
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 1h 48mn
Bit rate : 448 Kbps
Maximum bit rate : 1 350 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Stream size : 348 MiB (13%)
Encoded date : UTC 2011-01-12 21:17:10
Results 1 to 1 of 1
encoded video duration different than vob duration
By fatcharlie in forum Video ConversionReplies: 9Last Post: 4th Dec 2011, 10:04 -
Help with MP4 with wrong 2:35 AR instead of 16:9
By tigerb in forum Newbie / General discussionsReplies: 4Last Post: 25th Sep 2011, 22:52 -
NTSC DV to H264 MP4: Vegas renders wrong aspect ratio
By zigmond in forum EditingReplies: 30Last Post: 16th May 2011, 01:54 -
How to check the duration of multiple .mp4 videos?
By RiTu in forum Newbie / General discussionsReplies: 1Last Post: 12th Oct 2010, 15:50 -
Duration per media?
By 1gnition in forum Capturing and VCRReplies: 11Last Post: 14th May 2007, 08:22
