Just got an LG BluRay burner, WH10LS30.
When burning a Verbatim BD-RE disc (which is a 2x disc) using ImgBurn, the drive doesn't burn any faster than 1.1x, and the Device Buffer only goes up to 50%
Media: Verbatim 25GB BD-RE 2x - VERBAT-IM0-000
Burner: LG WH10LS30
OS: Vista 64-bit Home Premium
4GB memory
Anyone else run into this before?
Thats about right, 2x is the max speed it is capable of... much like your car is capable of 110mph, but you dont drive it flat out all the time. Look up CAV and try nerospeed, inner rings are slower.
Oh, I understand that it's the max speed, but the drive never burned past 1.1, no matter if I was burning 2GB or 24, and the device buffer never moved past 50% (it didn't drop lower either, which is good).
This behavior is only limited to the BD-RE (and I only have one to test on, since they're a tad pricey). DVDs burn at their max speed (or very close to it) and the device buffer is at 100% during those burns.
LG BH10LS30 blu ray burner, Doesnt seem to recognise blu ray media
By john8611 in forum DVD & Blu-ray WritersReplies: 11Last Post: 5th Feb 2012, 04:58 -
Dumb Question - Burning Blu-Ray movie with a standard DVD-R burner?
By toxicquack in forum Authoring (Blu-ray)Replies: 7Last Post: 18th Aug 2009, 04:59 -
Blu-ray burner on my iMac
By Nilfennasion in forum MacReplies: 5Last Post: 30th Apr 2009, 09:38 -
Blu Ray burner help
By dafoe in forum DVD & Blu-ray WritersReplies: 11Last Post: 8th Apr 2009, 01:14 -
Burning Blu Ray from ripped Blu Ray
By ppurdue in forum Blu-ray RippingReplies: 10Last Post: 15th Oct 2008, 20:51
