In GfD, you can make the subtitles default on by clicking the "Autostart" box in the file selection dialog after you choose the subtitle file.
With VLC to play a DVD fileset, do "Media/Open folder" and the select the VIDEO_TS folder. You don't select a VOB file.
You should then see the opening DVD menu screen -- GfD makes one with the name of the video file by default, which you can change, add images to etc.
If subs aren't displaying, "Video/Subtitles track" and select it.
After burning to a DVD, just use the normal remote button.
If the subs are out by a constant time, use Subtitle Workshop to add the 18 seconds or whatever.
"Edit/timings/set delay"
Note that you can have up to three subtitles in GfD. You can add both your new version and the original ones and see how they compare, playing them in VLC.
And "OT" is "off topic" as none of this relates to "29.97fps subs to a 25fps Video"
Results 31 to 35 of 35
Thanks, Alan. I'll try your last recommendation next. This is turning into much more trouble than I anticipated...
Convert FLV 25fps to 29.97fps
By Jason77 in forum Video ConversionReplies: 6Last Post: 17th Feb 2011, 17:34 -
converting PAL (25fps) to NTSC(23.97fps) with audio
By drew24 in forum MacReplies: 6Last Post: 21st Dec 2009, 10:45 -
Help with HD @ 29.97fps to DVD at 25fps
By Killer3737 in forum Video ConversionReplies: 9Last Post: 19th Nov 2009, 15:29 -
What Is The Good/Correct Method to convert from 25fps into 29.97fps..
By hypershade in forum Newbie / General discussionsReplies: 1Last Post: 21st Mar 2009, 08:49 -
avi is 23.97fps,srt is 25fps
By Soixante in forum SubtitleReplies: 7Last Post: 3rd Dec 2008, 15:26
