hi..i donno if its the right section but i m facing a serious prob..i m using htc evo 4g to record videos...it records at 720p(mpeg4 codec)...the thing is the video quality is awsome but sound is very very bad...just not acceptable...it looks as if only noise is recorded...very difficult to interpret the actual sound....its very hazzy...full of noise
please suggest me what should i do....is there any software that can eliminate this noise...any convertor which i can use to convert the video and get better sound on the converted format ? anythin else worth trying...i badly want the actual sound back !
any help will be appreciated
thanx..cheers !
	First, do an image search on "production microphone." Look at the pictures. Then, look at the microphone on your htc evo 4g. See the difference?
 You did not post a sample of the recording, but it's easy to conclude that any cheesy omnidirectional mic, especially without a windscreen, is going to pick up a lot of noise. The noise is further exacerbated by automatic gain control over the volume. Unless the sound source (such as a person speaking) is within inches of such a mic, crispness and clarity will be lost.
 Various audio editors (try Audacity) and processors can perhaps filter and equalize the sound to "improve" it a bit, but nothing is going to clean up a crappy recording.
	Thanks for the reply
 i know there is hell lot of difference between a mic on the phone and a production mic. But i would expect the mic on the phone to atleast produce decent, interpretable audio..? The sound source here in my case wasnt a person speaking..it was a live music performance(sorry forgot to mention) and my phone was both very close to the speaker and the performers...i got great video quality but audio is just not acceptable...u dont get a word of what was being sung
 Nevermind...i will give audacity a try...thanx
 Also..i donno if it will help but the output video files are all .3gpp extension..is there something i can do to them...like convert to some other format and rectify the audio in some way perhaps ?
	^^ i hv no option...i want a good camcorder badly...until i get one i hv only my phone as the recording source...is there some precaution or something i can do next time so that i get decent audio...like place it away from speakers...or somethin else...i m really desperate !
  No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad EverythingBy koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48
  bad day on the Google MobileBy Dr.Gee in forum Off topicReplies: 3Last Post: 26th Dec 2009, 15:06
  Bad deinterlacing when recording NTSC video on PAL sDVD recorder.By ramrod1234 in forum Capturing and VCRReplies: 10Last Post: 12th Oct 2009, 10:16
  VHS/ DVD Go-Video problem. Bad video, good audioBy Shempp Ranger in forum Newbie / General discussionsReplies: 3Last Post: 14th Apr 2009, 21:31
  Recording pc video/audio out to itself - how do I avoid audio reverb?By yoda313 in forum Capturing and VCRReplies: 4Last Post: 18th Feb 2008, 20:27
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
