I have a video (.avi-file) with a resolution of 544x576, but the resolution has to be 640x352.
Can someone tell me how I can change the resolution of the video from 544x576 into 640x352.
I tried to use VirtualDub, but the program didn't work because I couldn't browse the .avi-file in VirtualDub: wrong codec or something, the .avi-file wasn't a correct mpeg-4 (sorry, I'm a newbee).
I hope that you can help me. I don't want to cut off parts of the video, I want to stretch the video so the resolution is normal again.
I hope that you can help me!
Try a ffmpeg frontend like xmedia recode, load avi, choose avi with xvid video codec, under video change resolution, convert.
If it wont work try winff, format factory, any video converter free, etc. -
Thank you for your answers. I tried Mpeg4Modifier earlier, but I have the same problem with this program: I couldn't browse the .avi-file and any video converter isn't an option either, because when I change the resolution the program cut off parts of the video instead of stretching the video.
I couldn't open the file in the program, but I used xmedia recode today and it works!
Thank you all for your help.
What's the fastest way to change video resolution?
By Phantoms Cry in forum Video ConversionReplies: 2Last Post: 16th Jan 2012, 15:51 -
Change VOB Resolution
By Simmons in forum Video ConversionReplies: 4Last Post: 30th Aug 2011, 07:37 -
How to change RMVB video resolution?
By williegreg in forum Video ConversionReplies: 2Last Post: 30th Dec 2009, 14:27 -
How do I change video Resolution
By mmkk in forum Video ConversionReplies: 7Last Post: 31st Aug 2009, 17:33 -
How to change video resolution exactly in Virtual Dub Mod 16:9 to 4:3
By afcoff in forum Video ConversionReplies: 1Last Post: 12th Jan 2009, 11:49
