  1. hi how do i un compress audio using avi to vcd but it says cannot encode file it has compressed audio tried encoding with tmpge but results were not so good playback had like a net curtain over the top of it especially on the dark scenes. thanks chelly.
  2. Sounds like a DivX/AVI type, what you need is to use VirtualDub to open the AVI file, and then select Save WAV, and then use the WAV as the Audio Input in TMPGEnc.
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
