I have a basic Bell satalite box model 4100 with a S-VHS and analog video RCA output . I would like to use a Samsung computer monitor that accepts a VGA and DVI input.to view the picture (quality is not important) Can this be done using only S-VHS to VGA conversion cable ? or do I need an "electronic black box " to convert these signals. Thanks.
	an electronic black box Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	You need something like this:
 http://www.amazon.com/gp/product/B000XY6N5Y/
 http://www.amazon.com/StarTech-COMP2VGA-Console-Monitor-Converter/dp/B00006B8EI/Last edited by jagabo; 10th Jan 2011 at 08:41.
	[QUOTE=jagabo;2047126]You need something like this:
 http://www.amazon.com/StarTech-COMP2VGA-Console-Monitor-Converter/dp/B00006B8EI/[/QUOTE]
 Thanks for the information.
	For about $80 you could buy a simple TV that would get a better picture. A used CRT TV would be near free.
 Alternate, which I do, is add a tuner/capture card to your computer and run it as a window on your desktop. That way you can record the video you are watching. I also have the box feed a large screen TV which can remain off during most of the day.Last edited by edDV; 10th Jan 2011 at 18:12. Recommends: Kiva.org - Loans that change lives.
  vga output has stopped working and I don't know whyBy xtube in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2010, 03:33
  VGA output from ATI laptop to composite RCABy freeztar in forum Newbie / General discussionsReplies: 14Last Post: 3rd Feb 2010, 20:20
  Connecting DVD with VGA output to computer monitor.By danyalos in forum Newbie / General discussionsReplies: 1Last Post: 28th Sep 2009, 13:12
  Hardware advice, video card & monitor, DVI or VGA ??By Noahtuck in forum ComputerReplies: 7Last Post: 12th Jul 2009, 01:58
  cant output 1920x1080 through vgaBy sitlet in forum ComputerReplies: 13Last Post: 27th Jan 2009, 18:34
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
