  1. Hi folks,
    I'm trying to convert VOBs to MKVs. When I use the 'Copy Original' option for audio, everything works fine. But when I try to encode the audio using any of the codecs (Nero AAC, Lame, AC3), it gets stuck at the status "Encoding Audio with xxxx - First Normalizing Volume... wait". I though it might work if I removed the normalization option, so I opened 'Advanced Audio Options' and unchecked 'Normalize Audio' under 'Global Audio Options'. But the change didn't stick. When I reopened Advanced Audio Options, 'Normalize Audio' remained checked. I've included the log below. Any suggestions would be appreciated.
    Thanks in advance!
    13:12:39 0.98.4 - - - - - - - - - - - - - START JOBS - - - - - - - - - - - - - -
    13:12:39 Selected Input file: C:\DVD1\VTS_03_1.vob
    13:12:39 Selected Output dir: C:\MKV\temp\
    13:12:39 Selected Final Name: File1
    13:12:39 Selected Container type: MKV
    13:12:39 Selected Encoder: X264
    13:12:39 Selected Size: 1/2 CD / 1
    13:12:39 Selected Profile: 2_Pass_Balanced.xml
    13:12:39 Selected Resizer: NONE / Original
    13:12:39 Selected Filters: RemoveGrain(mode=2)
    13:12:39 Selected Deinterlacer: AUTO
    13:12:39 Selected Field Order: AUTO
    13:12:39 Activate PGC Ripping: 1
    13:12:39 Track Language 1: 80: English (AC3 2ch, 0xBD 0x80) [0]
    13:12:39 Audio Codec 1: Lame
    13:12:39 Audio Quality 1: 128
    13:12:39 Audio Channel 1: Stereo
    13:12:39 Track Language 2: NONE
    13:12:39 Audio Codec 2: Nero AAC
    13:12:39 Advanced Audio Settings DUMP Track 1
    13:12:39 Audio Track Language: und
    13:12:39 Nero Option Profiles: AUTO --- Encoding Mode: Quality
    13:12:39 CCT Option Profiles: AUTO --- Channel Options: AUTO
    13:12:39 Lame Settings: ABR
    13:12:39 Audio Normalization: 1
    13:12:39 Frequency: AUTO --- Tempo: NONE --- Pitch: NONE --- Other Add:
    13:12:39
    13:12:39 Activate PGC processing: PGC 1 [0:44:02:25]
    13:12:39 Dgindex CMD: C:\AutoMKV0983\exe\dgindex\dgindex.exe -FO=0 -OM=1 -TN=80 -YR=2 -AIF=[C:\DVD1\VTS_03_1.vob] -OF=[C:\MKV\temp\movie] -exit -minimize
    13:13:10 D2V file size: 336481 bytes
    13:13:10 Audio 1: movie t80 2_0ch 192kbps delay 0ms.ac3
    13:13:10 Pre Audio 1' Size: 63479808 bytes
    13:13:10 Applying DelayAudio of 0 to audio file: movie t80 2_0ch 192kbps delay 0ms.ac3
  2. May be some security programs block encoding? take a look...
  3. I've been having the same problem. It also occurs with the AVI container. AutoMKV will not encode audio at all and normalize checkbox resets. Running Win7 x64 SP1 and tried compatibility mode for XP, 98/ME, Vista, etc. and running as Admin. The only change is when running 98/ME mode I get an error that says the audio encoder crashed. I don't think Microsoft Security Essentials is interfering. Out of ideas
    edit- Found in other threads with this problem they were pointed to a program by the same author called HDConvertToX and one by somebody else called RipBot. Still having trouble with HDConvertToX unfortunately though.
