I need to convert a file (the new starwars ad which is an mov widescreen). how can i convert it to vcd mpg compliant video but keep the aspect ratio. in otherwords how can i add the blackbars to the top and bottom. oh and can any replies be keept to freeware software unless other software is absolutly needed.
thanx in adance for any help
Yup, same way you would with a regular DVD to VCD converion, tell TMPGEnc your source is 16:9 Display and that will fix it up for you.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
ok i tried setting the source as 16:9 but it still streches the image out to convert it
Make sure to set the arrange method to "Full Screen (Preserve Aspect Ratio)" It'll then letterbox it for you.
yeah it worked thanx very much can now make the episode 2 trailer on to svcd and what not once again thanx
Widescreen aspect problem converting avi to dvd
By spiritgumm in forum Video ConversionReplies: 8Last Post: 10th Apr 2010, 14:14 -
Converting from Mini DV - Problem with Aspect Ratio PAL Widescreen
By Videonisse in forum Capturing and VCRReplies: 9Last Post: 30th Jun 2009, 18:01 -
Converting a widescreen video for youtube
By theguy1991 in forum Video ConversionReplies: 9Last Post: 11th Jun 2008, 18:19 -
Difficulty In Converting .Vob to Any Format & Keeping Widescreen
By RachelArcher in forum DVD RippingReplies: 50Last Post: 10th May 2008, 11:40 -
Trouble converting widescreen AVIs to DVD format
By embreeb in forum Authoring (DVD)Replies: 7Last Post: 25th Jul 2007, 00:18
