Hello all, I've been "out of the game" in regards to video editing for some time and am trying my hand at getting back into it. I've come across a problem though. I'm trying to make a DVD of a video I recorded on my Tivo. I took out the "tivo junk" via DirectShowDump and created a .mpg file. This file played fine from begging to end in Microsoft Media Player. However, when I try to import it into most video editors (such as VituralDubMod) in order to cut out commercials, the audio become very out of sync while playing it. This is BEFORE I actually do any cutting so it is not a case of splicing a mpeg file incorrectly.
I believe this may be a case of missing frames in the video steam. After searching I tried a program called PVAStrumento to attempt to fix the mpg. It log found hundreds of what it calls missing frames in the video.
Is there anyone out there that can help me get this file either into a good mpeg or I would even be ok with a loss of quality to transcoding it to another format that can be edited.
Also, I am inclined to believe the missing video frames theory because the video is only 58 minutes long, while the audio is the entire hour.
"A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune -
Try VideoRedo to fix your video. I use it on all of my Tivo recording that I want to edit and do something with. Quickstream fix is the utility built into VideoRedo that can fix these time stamp issues. They have a fully functional 14 day trial if you want to tinker with it before you buy it. I have been using for 4+ years. Great program and they have great support on the forums.
Donadagohvi (Cherokee for "Until we meet again")
H.264 conversion/frames missing/skipped
By iGnight in forum Video ConversionReplies: 18Last Post: 29th Jan 2011, 02:23 -
AVI jerky/missing frames?
By MdMa11 in forum Video ConversionReplies: 10Last Post: 25th Apr 2010, 23:13 -
missing frames
By carmatic in forum RestorationReplies: 11Last Post: 19th Feb 2009, 21:06 -
Mpeg 2 for Blu-ray audio exports with missing frames at beginning and end.
By jbandy1 in forum EditingReplies: 0Last Post: 21st Jan 2009, 16:34 -
Jumpy video with animated films - like there are frames missing!
By junks in forum Authoring (DVD)Replies: 8Last Post: 10th Jan 2009, 09:27
