  1. I want Mplayer to start allways with 16:9 aspect ratio.
    But even if i change "monitor aspect" to 16:9 this option is not saved.
    Any solution to force this AR when Mplayer open any file or url?
    Oct 2010
    England
    Are you familiar with Mplayer's config file? Add the following to it, on a new line:
    vf=dsize=16/9
    The location of the config file will be different depending on the OS you're using. Under Linux, it's located at $HOME/.mplayer/config. I'm trying to find out where it is for Windows users.
    What OS are you running?
    EDIT: From this page:
    http://wiki.multimedia.cx/index.php?title=MPlayer_FAQ
    - 'on windows its in the mplayer directory where mplayer.exe is. for example c:\mplayer\mplayer.exe the config is c:\mplayer\mplayer\config'
  3. I've tried to add this line in many combinations: on top, under video filtering, new line, but had no effect.
    Oct 2010
    England
    You've got a # symbol at the beginning of the line. Lines beginning with at least one # are interpreted as:
    - a user comment and are ignored by the program
    - they can also be used to disable a configuration option without having to delete the line from the config file
    ##vf=dsize=16/9 is invisible to Mplayer - remove both hashes.
    If you want to add more video filter options to the config file, you can chain them together as one line with commas between them:
    vf=dsize=16/9,flip,eq2=1:1:0:0
    This example controls the aspect ratio, flips the image upside down and desaturates the image.
    Adding multiple vf options on more than one line won't work properly:
    vf=dsize=16/9
    vf=flip
    vf=eq2=1:1:0:0
    In this example the third 'vf' option will override the previous ones.
    EDIT: By setting the aspect ratio to 16/9 in the config file, all videos will be formatted to it - 4:3 videos will be s-t-r-e-t-c-h-e-d horizontally.
    What's the reason for forcing all videos to 16/9? If you're trying to correct an individual video with the wrong aspect ratio, it should be possible to temporarily change the picture format via a menu option.
  5. Originally Posted by intracube View Post
    I'm watching tv on pc via sopcast but all channels are in 4:3 AR.
    With VLC or Mplayer the image quality is better (postprocessing) and all channels can be watched in full screen on 16:9 without any distortions.
    I've assigned a key for quick change between 4:3 and 16:9
    Thanks for answers.
