I used a couple of templates found here in the Tools section with TMPGE and when it seems to be finished encoding, down to 0 time left, it just sits there and doesn't give me any kind of dialouge box saying it is complete. The elapsed timer keeps counting like it is still working, but I can let it go 20 minutes after the completion clock hits 0 and it still hangs.
I can hit the abort encoding button to stop the process but then my system hangs. The encoding seems to work, but it sure is a pain having to reboot after every encode.
When the process is complete am I supposed to get a finished dialouge box? What am I doing wrong?
Kwag, BTW if you read this your template works great !! As good quality as the SVCD's I burned, more fits on the CD, AND you don't need to do the painful SVCD encoding !!!! Thanks for that bit of knowledge !
Results 1 to 1 of 1
TMPGENC encoding problem
By whschlebaum in forum Video ConversionReplies: 0Last Post: 26th Apr 2011, 22:22 -
TMPGEnc Author Keeps Re-encoding
By lostinspace00 in forum Authoring (DVD)Replies: 13Last Post: 8th Apr 2011, 08:16 -
Encoding using TMPGenc 4.0 Xpress
By abdul_sma in forum Video ConversionReplies: 1Last Post: 19th Jun 2010, 07:15 -
TMPGEnc Plus Encoding
By crys94 in forum Video ConversionReplies: 9Last Post: 29th May 2008, 22:23 -
TMPGEnc Conctant or Variabile Encoding
By MI6 in forum Video ConversionReplies: 1Last Post: 2nd Sep 2007, 06:49
