Downloaded a movie it want play in my dvd player but it will play in my play station 3 it will play fine for about 10 min. then the sound kicks out after that it will play with no sound Is there a way to fix this? did a different movie did the same thing i guess its some type of protection? I think it a mp4 , or video cd i had to put it on a dvd dics
Results 1 to 18 of 18
lots of luck getting help on this one. sounds a little fishy.
If it's an ambulance...you got a chance. If it's a hearse...it's even worse!!!--Judge Alvin "JP" Valkenheiser
Want to extract audio from .vob files? Read my guide at https://www.videohelp.com/forum/viewtopic.php?t=187078 -
i got other movies they will work fine but some will play for 10 min then no sound (movie is salt and other guys}
u been a member since 2003 you should know better not to ask questions about this topic
make up a story next time lol
don't include downloaded movie,movies name,,,, -
my dvd player won't play it ps3 will play it run for about 10 min. sound stop it sill play's video
oh here goes ps3 says audio output temporarily muted,protected by Cin____,message code 3
This particular form of copy protection is supported by the PS3 and will be supported by newer bluray and DVD players. It embeds some form of encoding in the audio track that is specific to the format. Cinema audio will have a different code to the DVD track, which will be different to the bluray track, which will be different to the digital download track. If the audio does not match the format - e.g. you convert your bluray to DVD - it will not play. It also affects conversion of bluray to AVCHD on DVD, and prevents the use of cinema audio on foreign (e.g. R5) releases that don't have English audio tracks. To date there appears to be no way to strip out this encoding or prevent the player detecting it. Manipulation of the audio - encoding to different formats, stripping out high or low frequencies, alterations to samples rates etc - do not affect the way the protection work.
Read my blog here.
dvd player wont play AVI or dvd video burned discs
By rockerman in forum Authoring (DVD)Replies: 5Last Post: 20th Oct 2011, 13:01 -
Downloaded DVD footage will not play in SA dvd player
By rockonvidtrade in forum Authoring (DVD)Replies: 2Last Post: 27th Mar 2008, 20:26 -
DVD Player wont play DTS 6Ch, can i change Audio?
By snadge in forum Newbie / General discussionsReplies: 31Last Post: 16th Jan 2008, 06:12 -
Ive copied a avi disc but it wont play on my dvd player
By popeye39 in forum Newbie / General discussionsReplies: 2Last Post: 9th Sep 2007, 15:26 -
Downloaded VOB, BUP IFO files won't play in dvd player
By COOPERMAN100 in forum Newbie / General discussionsReplies: 5Last Post: 28th Aug 2007, 05:31
