Hi. After trying a few different video converters I've decided to stick with AVS Video Converter 7.1. However, I'm a bit bemused by the 'Aspect Correction' tab – I can understand why you would want to specify how the output video should look but why would you want to change the INPUT video? Surely the program can read the properties of the file you've just loaded...
Here's an extract from the program makers' own website which doesn't help me at all. If anyone can explain to me how and when to use the 'Input Video Aspect Correction' options I'd be very grateful.
Because not all video has correct aspect ratio flags. You would force change settings if "original" showed the wrong aspect ratio. It should also insert the selected flags into the converted video.
http://www.kiva.org/about -
The input source video could have wrong display aspect ratio. Or AVS might have problem reading the correct aspect ratio.
Auto adjusting screen resolution to video resolution
By Computer Nerd Kev in forum Software PlayingReplies: 11Last Post: 11th Jul 2011, 07:36 -
Adjusting volume of video files
By pooksahib in forum Newbie / General discussionsReplies: 3Last Post: 7th Mar 2011, 14:48 -
mic input -realtime denoise -> sent as input to dragon naturally speakin
By logicom in forum AudioReplies: 0Last Post: 27th Sep 2009, 12:46 -
Compatibility of composite video output VCR with component video input TV
By boshu22 in forum Newbie / General discussionsReplies: 7Last Post: 7th Sep 2009, 23:46 -
adjusting the volume of individual clips in AVS Video Editor
By DaneClark in forum EditingReplies: 1Last Post: 12th Jul 2009, 04:05
