I am new to the forum - this is my first post. I have recently started converting some of our old family home videos from Hi-8 to DVD, but I've run into a problem...
I had gotten the old tapes out and our DVD recorder and started recording them myself. But I found out from my father that he'd already done it, and I asked to borrow his discs to copy them and a ton of time.
His discs are the usual size, 3 or 4 gb each. But when I copy the Video TS folder to my hard drive and go to play the movies, it lists the run time as something like 78 hours! In reality, they are only 2 hours max.
I've been wanting to convert the files to AVI, but the one file took 24 hours to convert and the final product is 40 gb! The true runtime of this particular one is about 20 minutes, but the computer thinks it's 16 hours.
So I started just making my own DVD's of the tapes and one has a normal runtime but others don't - I am not sure what was done differently with recording them, but I will play around with it.
The problem is - there is ONE tape that means a whole lot to me. And I can't find the original Hi-8 tape. The only thing I have is the DVD with a 76 hour runtime (regardless of what program I open it with). I can play it as a DVD, but I can't do much else with it like this.
So - my question is, is there any way to fix this without having the original tape?
Thanks so much for any help!
If it's important - my OS is Windows 7, and I have tried several different video editing programs and the issue is the same with each.
DVD --> ISO using dvddecrypter then load the iso file into fairusewizard and convert to avi/divx.
I need to transfer my miniDV and old hi8 tapes tapes to dvd
By bryanport in forum DVD & Blu-ray RecordersReplies: 9Last Post: 21st Dec 2012, 20:53 -
ffdshow is insane
By El Heggunte in forum Off topicReplies: 4Last Post: 9th Oct 2010, 13:36 -
DVD to H.264 - Different Running Times, Chapter Times Wrong
By nrogers64 in forum Newbie / General discussionsReplies: 0Last Post: 17th Mar 2009, 19:28 -
ffmpeg converts DV .mov to .avi, results run 5 times too fast
By sybariten in forum LinuxReplies: 1Last Post: 13th Jun 2008, 14:48 -
Blockbuster... are they insane???
By MeDiCo_BrUjO in forum Off topicReplies: 11Last Post: 21st Dec 2007, 00:44
