Hi everybody
I was able to download a small Flash video on my PC but, the resulting file presents ONLY audio; video appears black.
I tried RealPlayer Downloader and Grab++ (tool embedded in Orbit Downloader) and I got the same result.
The video in object is here.
Could anyone help me?
Greets from Italy![]()
WinXP SP3-ASUS P5K-Intel Core2 Quad Q6600-Kingston DDR2-800 4GB-Maxtor STM3320613AS-LG GSA-H42N-PHILIPS SPD6002T-Gainward 9500GT-Pinnacle 700-PCI-Realtek HD
The "video" is not really video. It is a Flash presentation with multiple moving objects in an SWF file with a synchronized audio track (and a linked text track in in XML). Only the audio is in the linked FLV file.
Is there a way to capture everything?
WinXP SP3-ASUS P5K-Intel Core2 Quad Q6600-Kingston DDR2-800 4GB-Maxtor STM3320613AS-LG GSA-H42N-PHILIPS SPD6002T-Gainward 9500GT-Pinnacle 700-PCI-Realtek HD -
Thanks a lot, I'll try
As you already have the audio, you could try to open the flash swf file alone:
http://reps.acneuro.com/ACN-Europe_files/presentation/businessPress_002.swf?loadURL=la..._IT_IT_002.xml
That will give you a better (bigger) image to capture, or your downloader will download the swf file directly.
But you still need 3 files to build up a viewable video - so capturing will be easier if you´re not familiar with flash.
Good luck.Last edited by NoBuddy; 18th Jan 2011 at 23:42.
Strangest problem randonly occuring with downloaded FLV files
By apak in forum Newbie / General discussionsReplies: 1Last Post: 10th Sep 2010, 05:44 -
Improve Quality of Downloaded FLV files..
By Deter in forum EditingReplies: 4Last Post: 9th Jul 2010, 21:25 -
How to get a quality DVD video from a downloaded 'flv format (Real Player)
By elaway in forum Newbie / General discussionsReplies: 4Last Post: 17th Jan 2010, 19:39 -
Protect Video Files From Being Downloaded (FLV)
By foochuck in forum Video Streaming DownloadingReplies: 1Last Post: 12th Oct 2009, 14:06 -
FLV audio out of sync, can't work VirtualDub w/ FLV plugin
By ZantarV in forum Video ConversionReplies: 1Last Post: 4th Sep 2009, 11:51
