Hi all,
I'm trying to convert video I captured from my sony digital camera to divx. The problem is, that the capture from the camera is a MS DV Video avi. When I try to encode it to DiVX with VirtualDub or vidomi, I get an error message, stating that I need to have a VFW-avi file to start with.
So my question is, how do I convert my DV movies into DiVX???
The main concern is to keep the quality as good as possible.
PLEASE, any help is greatly appreciated,
TriHorn
MS DV codec is Directshow.
VirtualDub is Video for Windows (VFW).
You need to get a VFW codec for VirtualDub to read it. Try the
MainConcept codec (www.mainconcept.com free trial for decodes
only, encodes add watermark).
You can see Virtualdub.org for details under the support section.
It will also explain DV Type1 and Type2 files.
Virtualdub Error Message - Failed to load FFmpeg.dll
By SOSmkII in forum Video ConversionReplies: 5Last Post: 6th Feb 2012, 08:14 -
Opening Avisynth script on virtualDub - Error Message
By HugoBraule in forum Newbie / General discussionsReplies: 2Last Post: 25th Apr 2010, 22:48 -
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 21:18 -
Error message when opening AVI in Windows Media Player
By gomer in forum Newbie / General discussionsReplies: 1Last Post: 27th Oct 2007, 14:53 -
Error message popup when opening folders with vids
By majax79 in forum ComputerReplies: 32Last Post: 26th Sep 2007, 03:31
