    Jan 2011
    West sacramento CA
    I'm using fraps to capture video gameplay but the files it makes are too big. I'm looking for a similar application like fraps but with video codec support like divX and Xvid mp4 etc.
    ?Any recommendations? Thanks
  2. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Yeah, try DXTORY, the best software capture ever.
    Awesome capture, various codecs capture, no lags for gameplay, no 4gb limitation from FRAPS.
    Jul 2009
    Spain
    Cauptain, no need to shout.
    If all your posts are in bold, what are you going to do when you need to emphasize a point?
  4. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Sorry I just put same in other forums since 2000 . Not to give emphasis or anything.
    As I saw no obligation, I continued. If it's wrong, I change the my way post. No problem sir.
    Claudio
