i installed avstodvd, and burned a test disk, it worked. however, when i press the button that says "preview title output", i hear the audio playing back, but there is no video, it just shows a blank gray screen. i am working with DV-AVI file, but i tried an .mpg file and the preview doesnt show either.
Results 1 to 10 of 10
i installed ffdshow, and put the setting that was suggested in the FAQ, now the preview works.
was downloading ffdshow necessary for the preview to work? or was there some option that came with avstodvd that could have enabled the preview to work?
also, after i installed avstodvd, i cannot play back clips in windows movie maker... the preview in movie maker doesnt work
what do i do?
i tried uninstalling avstodvd and the other 3 programs that came with it, and movie maker still doesnt play back my dv-avi clip in the preview! i tried unchecking "avi decompressor" and "haali media splitter" from the compatibility tab in WMM options, but the preview still doesnt work.
looks like WMM is just as crappy as it was on XP
It could be a codec issue: be sure that in ffdshow video configuration, the DV support is activated (libavcodec). If it is already activated and preview in Movie Maker still does not work, de-activate ffdshow DV support and try with a dedicated codec like Cedocida.
Bye -
hey, i did what you said. dv support was deactivated in ffdshow. i activated it, and movie maker still would not let me preview my dv-avi files. i deactivated it and downloaded and installed cedocida, but that didnt fix teh problem either.
i right clicked on cedocida's .inf file and clicked install. i saw some screens just flash by, or something flashed for a millisecond and that was it. so i dont even know what installation happened. i see the program in my uninstall programs utility in windows though. is there a configuration screen for cedocida that i have to access? cause i dont see it anywhere.
what do i do next? -
Do not panic. If you right click'd on inf file, then cedocida codec is installed. If preview in WMM still does not work, then it is not a codec issue, so we have to look for another cause.
What operating system are you using?
Bye -
im on vista 64 bit.
i think its only the dv-avi files that WMM cant play, cause i opened up a .mpg file in WMM and that file previewed just fine.
i am using windows movie maker by the way, not windows live movie maker.
Cutting in Virtualdub yields gray pixelated video
By silverwolf0 in forum Newbie / General discussionsReplies: 0Last Post: 13th Dec 2010, 08:21 -
AVStoDVD crashed on audio encoding.. have m2v video file, but no audio
By arcooke in forum Newbie / General discussionsReplies: 3Last Post: 5th Aug 2010, 14:18 -
Audio but no video using AVStoDVD
By jaco33 in forum Newbie / General discussionsReplies: 6Last Post: 23rd May 2010, 22:40 -
Nero Vision - preview screen when burning
By bigj7489 in forum Authoring (DVD)Replies: 0Last Post: 15th May 2008, 12:57 -
Video Advantage PCI: Interlaced Video/No Live Audio Preview/Other Questions
By acid_burn in forum Capturing and VCRReplies: 2Last Post: 8th Feb 2008, 20:03
