So the latest dev builds of ffdshow have added support for many new codecs, and fixed bugs - but the devs removed several video capture codecs... which is a bit of a problem. While it appears the Xvid codec they used for capture was old and buggy, ffdshow's frontend allowed me to set the capture parameters very easily, and everything worked perfectly.
But of course, now that it's gone, I need help.
Is there a way to install the latest version of ffdshow, and have the older version installed solely for video capturing? I'm currently testing out the latest Xvid codec (Xvid_130_RC1_02012011.exe) and while it works, it really doesn't allow for multiple capture / export profiles. Note that I'm not having any hardware problems, my issue is with the software. (If this is the wrong forum then please move it, I wasn't sure whether to stick it here or the software forum!)
Thanks.![]()
I'm using Windows XP Pro 32bit, so I can't do that.
It's not a bad idea though!
Is this the correct way to install ffdshow just for VirtualDub?
By tigerb in forum Newbie / General discussionsReplies: 8Last Post: 25th Nov 2013, 01:23 -
FFDSHOW won't install on Win2k
By DanielF in forum Software PlayingReplies: 7Last Post: 27th Apr 2013, 05:12 -
Can I install two different versions of FFDShow on a single PC?
By Foxhack in forum Newbie / General discussionsReplies: 2Last Post: 4th Feb 2012, 00:52 -
Copies Of DVD5's
By kpoman in forum DVD RippingReplies: 5Last Post: 22nd Oct 2008, 23:33 -
Uninstall/Install over or Install new versions separately?
By MindF in forum ComputerReplies: 2Last Post: 5th Apr 2008, 13:43
