Hi,
I'm trying to convert an .avi file into a DVD. I followed the steps in the "how to". The conversion process is finished, but now that I'm ready to burn the fil, I can only find an .mpg file. It seems that no AUDIO_TS or VIDEO_TS or movie.dvd file was produced by the converter.
Anybody know what I have done wrong?
Thanks in advance
Possibly there was some kind of error between creating the .mpg file and using that to create a VIDEO_TS folder. The Process Information log could confirm that. (You may access this log by clicking the blue "i" in the ffmpegX Progress window.)
Did you try to include subtitles? If so, what format?
Did you try playing the .mpg file? Is it complete?
Thank you for responding
I used the how to on the ffmpegx page - http://www.ffmpegx.com/dvd_sub.html
Unfortunately I closed the Progress window, is there a way to bring it back to access the process info log?
I included subtitles in .srt format
I tried to play the file with VLC, with DVD reader and with Quicktime, it doesn't work.
The log is only in memory; if you quit Progress.app, the log is lost. I'm afraid you'll have to encode again to see the log again.
Okay, SubRip .srt is good.Originally Posted by Ursula514
If the .mpg file doesn't work, then perhaps the error happened earlier in the process, before the inclusion of the subtitles and before trying to create the VIDEO_TS folder.
If VLC won't play a file, then it is expected that other players won't play it either. There are some exceptions, but not with AVI or MPG.Originally Posted by Ursula514
Duplicate a DVD....can you simply copy Audio_TS folder and Video_TS folders
By True Colors in forum Authoring (DVD)Replies: 6Last Post: 29th Apr 2010, 15:37 -
I don't get any movie.DVD folder (audio_TS & video_TS), help!!!
By dbedolla in forum MacReplies: 1Last Post: 10th Nov 2009, 04:21 -
Copying a Recorded DVD--Video_TS and Audio_TS
By solarblast in forum DVD RippingReplies: 14Last Post: 23rd Jan 2009, 08:41 -
AVI to DVD not outputting Video_TS or Audio_TS folders
By threesixes in forum ffmpegX general discussionReplies: 18Last Post: 30th Dec 2008, 02:23 -
How do I rip DVD to VIDEO_TS/AUDIO_TS folders?
By Crimea in forum Newbie / General discussionsReplies: 6Last Post: 18th Feb 2008, 12:34
