when i put a dvd movie or program into my dvd drive( i have 2) it doesn't see the dvd. when i put in a cd it plays fine. i have changed the dvd rom and the cable to it. anyone please![]()
I had one do this, the drive died when this happened to mine. You could try taking out the drive and cleaning it.
It Started In Texas -
If those programs are on dvd media and it's this media giving you issues then it's possible the diode which controls the wavelength frequency required for reading dvd's is out of spec ... the one which controls the wavelength for reading cd's is fine ... it's time to replace the unit.
i have tried replacing with another that i have and the same problem occurred . i tried cleaning the dvd writers and still the same, could it be the motherboard is just getting old?
Are dvds not seen by dvd drive commercial dvds or dvds burned by the OP or other person, and what brand and model are the 2 dvd drives?
it does not matter if they are burned dvds or store bought and the brands are hitachi-lg and toshiba. just looked at dates on them and they 2006 and 2005
Dell with a NEC 2100AD DVD+R writer - flash update to write to DVD-R?
By DirtBikeMike in forum ComputerReplies: 5Last Post: 30th Sep 2010, 11:24 -
Avatar Movie DVD is not recognised by DVD writer in my PC
By coolsatya4u in forum Software PlayingReplies: 18Last Post: 6th May 2010, 03:24 -
Asus DVD 2014 L1T Writer fails for DVD +- DL
By fjmr in forum DVD RippingReplies: 8Last Post: 11th Aug 2008, 17:38 -
DVDs burned in Samsung DVD Writer only possible to watch in some DVD Player
By jorgepe in forum DVD & Blu-ray WritersReplies: 9Last Post: 4th Jan 2008, 03:15
