Results 1 to 20 of 20
  1. Member wingspar's Avatar
    Dec 2009
    This subject is not covered in the manual at all. Only still image focusing is talked about in the manual. I do not use the video cam for still images.
    While recording video, I may want to hold an object close to the camera for a closeup. When I do this, most of the time, the object is totally out of focus, while everything in the background is in focus. Same if I am taping someone who is standing too close to the camera, they will be out of focus while the background is in focus. (Camera is on tripod)
    How does the auto focus of this camera work?
    There is no focus sensor in the viewfinder as there is with still cameras. Where is the camera focusing?
    Does the focus distance change depending on whether you are shooting wide angle or zoomed in, even just a little?
    Gary
    Will Fly for Food
  2. Most cameras and camcorders have differet auto focus "modes". You can set them to preferentially focus on what's in the middle of the frame, a balance of the entire frame, or something in between. Check your manual.
    Another problem you may be having: the minimum focusing distance may be too far for close up work. Ie, there is a minimum distance at which the camera can focus. Any closer than that will never be in focus. That distance will vary depending on other parameters like whether you are at full zoom, full wide angle, and the current aperture setting.
    Oct 2005
    666th portal
    it's got manual focus for shots where auto won't cut it. up near the front press the "focus" button and control focus with the wheel next to it.
  4. Member wingspar's Avatar
    Dec 2009
    If there was anything in the manual, I wouldn’t have to start a thread like this. There is zero on auto focusing while video taping, but there is for still photos. Go figure. Makes no sense to my why they would not cover the video focusing in the manual on a video camera.
    That is the exact information that needs to be in the manual. It’s starting to look like the only way I will find an answer to my question is to tape at different focal lengths at several fixed distances.
    That won’t work when there is no one behind the camera. I need auto focus to work by itself while on a tripod with no one behind the camera.
    Gary
    Will Fly for Food
  5. Member zoobie's Avatar
    Feb 2005
    Florida
    try setting the camera across the room and to full zoom
    Mar 2008
    Near the Beach
    Have you played around with "Instant AF" and "Normal AF" - any difference?
  7. Member wingspar's Avatar
    Dec 2009
    I’ve never messed with I-AF and AF. I messed around with it for a few minutes in the house this morning, but the results were worthless. Couldn’t seem to focus on objects 5 feet away in AF.
    Later in the day I got out, with the camera set to the default (came that way) to I-AF, and did some tests at different distances and different focal lengths. No problems. Focus seemed fine. I’m wondering if the auto focus has a hard time in low light situations. DOF seems really shallow. Unfortunately, I didn’t think about trying AF out there. Had other things on my mind.
    As a sports photographer, shooting tight has been ingrained into me for years, it’s hard to get away from that. Maybe I just need to shoot at the widest angle, and set the camera closer. I don’t know. Sure wish the manual talked about this. Also be nice if you could see the focus point in the LCD screen like you can when shooting with a dSLR, and be able to move the focus point around. That would sure be nice. Guess I’ll just have to set a time to experiment and see what I come up with. Maybe I could use the manual to start a fire with...
    Gary
    Will Fly for Food
  8. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    AF works through the lens and is rather slow and hunts around frequently. i-AF works off a small sensor on the front of the camera body, and i don't think it functions like a SLR focus.
  9. Autofocus (based on the image data) always has a hard time in low light situations. It needs high contrast, sharp edges to focus.
    As aedipuss suggested, instant autofocus uses a separate sensor, and probably an infra red lamp on the camera.
  10. Member 2Bdecided's Avatar
    Nov 2007
    IME I-AF snaps things into focus quickly, even when zoomed in, even in low light. The HV20 is certainly one of the batter camcorders I've used for auto focusing.
    Depends on your definition of low light I suppose. On my HV20, the image is getting grainy long before the I-AF fails. The HV20 doesn't really work at all well in really low light!
    Cheers,
    David.
  11. Member wingspar's Avatar
    Dec 2009
    After reading your post, I got the manual out, and in the front of the manual is a diagram showing the I-AF sensor on the front of the camera. To the left of the lens looking at the camera. To the right of the lens if you are behind the camera. I would never have guessed it was anything but thru the lens. No way to move the focus point, that’s for sure. How does the camera decide what to focus on then? Closest priority?
    Low light in this case is around 4:45 in the afternoon, well after the sun set, but not really dark yet. If I held an object in front of the camera, it would just be a blur, but when I did it in daylight, it was in focus. I was beginning to think that it was a low light situation as far as the focus went. Even on cloudy overcast days with plenty of light, I get this problem. Also, the camera seems to have a very shallow DOF for things within 10 feet of the camera, which will end up with part of the subject in focus, and part out of focus. I saw this in bright sunlight yesterday.
    This is an HV30, but operation is probably the same as the HV20.
    I think if this was a $20,000 pro camcorder, I’d find it easier to operate. I can take any dSLR, and be at home instantly, but hand me a point and shoot, and I’ll be tearing my hair out trying to figure out how to do some things.
    Gary
    Will Fly for Food
  12. Originally Posted by wingspar View Post
    That doesn't sound normal.
  13. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    do you have anything on the front of the cam that might block the i-AF sensor? lens hood? lens adapter? the 20k pro cam would only be easier in manual focus because of the more familiar focus ring. the little wheel takes practice and getting used to.
  14. Member 2Bdecided's Avatar
    Nov 2007
    If you're used to SLRs, it's bizarre that you think an HV30 has a shallow depth of focus! You only get anything approaching typical SLR DOF effects when you zoom in on a somewhat distant object.
    that's not really meaningful on an international forum!!!!
    in which case I wouldn't expect an HV30 to work well at all. Or any consumer camcorder. They don't work without light.
    Cheers,
    David.
  15. Member wingspar's Avatar
    Dec 2009
    No. Do lens hoods and lens adapters tend to block the focus sensor? I am considering a hood and wide angle lens, but if they block the focus sensor in anyway, I see no reason to waste my money on them
    I did two videos with me in front of the camera at an angle with my hands extended. In one of the videos, my hands were out of focus, but I was in focus. In the next video, my hands were in focus, and I was out of focus. It’s something I don’t see till I see the video on the computer monitor at home, and it makes the video useless.
    I didn’t think it was That dark, but I guess it was.
    Gary
    Will Fly for Food
  16. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    most hoods and adapters will block the i-AF sensor. looking from the front of the cam it's on the left side of the body next to the lens under the aux light/flash.
  17. Member wingspar's Avatar
    Dec 2009
    I now know where the sensor is. So adapters block the I-AF sensor? What good are the adapters then?
    The hood I was thinking about is the Fotodiox 43mm Square Hood.
    Gary
    Will Fly for Food
  18. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    i wouldn't use a hood if you plan on shooting sports or any vids with movement. without the i-AF sensor working perfectly the cam defaults to AF and it then does a poor job on action scenes.
  19. Member wingspar's Avatar
    Dec 2009
    Ok. I’ll have to re-evaluate a hood, but I see the price of the hood has gone from $17.95 last year to $7.95 now. Still, if it interferes with the I-AF sensor, I’ll pass on the hood.
    Thanks for the help. I’ve learned a lot about my cam in this thread, and if I ever buy another cam, it will have to I-AF thru the lens.
    Gary
    Will Fly for Food
  20. Member wingspar's Avatar
    Dec 2009
    Duplicate Post.
    Last edited by wingspar; 13th Jan 2011 at 14:02. Reason: Site is deathly slow, causing me to post twice not knowing if the first one posted.
    Gary
    Will Fly for Food
