i tried 3 different programs to record my home movies from my minidv camcorder onto a DVD. on the camcorder, the video plays back smooth like water, but when i convert the video to DVD format, the video becomes more choppy, as if there was a drop in FPS during conversion.
i capture video to DV-AVI format, and then convert to DVD format, and thats what happens.
Results 1 to 9 of 9
DVD is capable of displaying 480i video (what most DV camcorders shoot) when properly made. You need to encode as 720x480, interlaced, bottom-field-first. Then author the DVD as such. It sounds like you may have encoded as progressive or top-field-first instead.
As jagabo says, DV-AVI is bottom (or lower) field first. You have told us absolutely nothing about how you are encoding that footage to DVD (what software and what settings), but it indeed sounds like you left your encoding settings at either top field first or progressive. Field mismatches will definitely result in jerkiness -- especially in motion shots.
Try a few test encodes using 10-second clips at various settings until you get the best results. -
i downloaded DVD Flicker from this website, and i tried making a DVD in it out of an DV-AVI file, i was able to remove the interlacing by selecting the option, but the framerate still didnt look so good.
how do i make sure i have bottom field first in flicker? or what other free program will allow me to select BFF and burn a dvd? -
DV 720x480i has 59.94 motion samples per second (as fields). If you deinterlace to progressive 29.97 fps, half the motion samples are lost.
http://www.kiva.org/about -
well avs2dvd works much better it seems.
what is the maximum bitrate i can set in the program for the dvd? 8.5mbits? will a disk play in the dvd player if i set the bitrate to like 13mbits? will that make the quality better? how what bitrate should i pick to make about an hour of video fit on a dvd? -
Max video+audio+srt, etc is 9800 Kb/s. If you use PCM audio that works out to about 8250 max for video. For AC3 or Mp2 audio you can max video around 9500 Kb/s.
See https://www.videohelp.com/dvd for details
Also see the bit rate calculator
https://www.videohelp.com/calcRecommends: Kiva.org - Loans that change lives.
The maximum bitrate for everything on a DVD is 10080 Kbps. The maximum for the video is 9800 Kbps.
Force Higher FPS?
By therock003 in forum Software PlayingReplies: 5Last Post: 18th Apr 2012, 17:26 -
mixing 1280 x 720 29,97 fps and 1440 x 1080 25 fps in final cut
By perik in forum EditingReplies: 6Last Post: 17th Nov 2010, 22:42 -
how to change fps in mp4 without reencode (maybe ps3 cannot handle 24 fps)?
By redout66 in forum Newbie / General discussionsReplies: 1Last Post: 14th Sep 2010, 04:53 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 15:23 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 19:17
