I have a problem, I was using window 7 from the last 6 months and yesterday when i reinstall the window my audio system was not working, i tried to reinstall the drive, but nothing happen, some search asked me to unistall the USB ports and restart the system, did it but nothing happen. When i do automatic window update, it says driver can not install succssfully, tried to fix it through device manager, when i click on sound, vidoe and game controll it says "The device cannot start code 10.
Have no idea what to do more, please do help.
Thanks.
Results 1 to 12 of 12
Did the audio stop working BEFORE the re-install of Windows? If not, what caused you to re-install Windows?
What type of audio device and how is it connected to the system?
Where did you get the drivers for the audio hardware and are you ABSOLUTELY CERTAIN these are the SAME drivers that were previously installed and working? -
More info about the system involved ... laptop (make/model) or desktop (include motherboard make / model)
Error 10 ... usually three issues
1: Incorrect drivers ... make sure manufacturers motherboard drivers are installed first ... you may need to use an older audio driver package if the latest fails.
2: Device unable to obtain required resources ... possible conflict with another device
3: Device failure -
Do you know any reliable site to dl or update drivers, my system is PackardBell IXtreme Gold 5190.
Thanks. -
If you would answer the questions I posed earlier, further progress will happen.
Audio stopped after the re-install of the window, the reason i did reinstall was not any especial, the system get quite heavy i that it is due to malware or virus, but after cleaning several time i did not find soluation, so i thought probably re-install will faster it again.
The sound driver came with the system, PackardBell IXtreme Gold 5190, that originally the system had window XP, but last year i changed it to window 7, and working perfect, sound/video/usb etc etc.
But now even i dl the driver from the PackardBell site, it is not working. -
Did you do an upgrade install to Windows 7, or a complete format and install? This is in reference to the FIRST Win 7 install which resulted in working audio. Was there an update to the sound drivers at that time?
Do you understand the difference between the two install methods?
Did you do the necessary research do make certain that all your hardware and drivers were compatible with the new, upgraded OS?
Was the SECOND Win7 install a complete format? This would have been necessary to remove any viruses.
My guess at this point is that you have a sound card with XP drivers that will run under Win 7 after an upgrade, but will only install under XP. Usually you can work around this by manually installing the drivers, rather than using the setup program included with them. Sometimes not.
As always, more information will result in more accurate guesses.
The drivers you downloaded, were they identified as Win 7 drivers, or XP? Were BOTH available for download?
The type of audio device is important as you may be able to get updated drivers direct from the manufacturer. Creative, Realtek, or somebody else?
Both win 7 installs SAME VERSION? Were either 64-bit?
There's also the possibility that the sound card just happened to die at this point in time.Last edited by Nelson37; 12th Jan 2011 at 11:03.
The complete format resulting in working audio indicates the built-in Win 7 drivers were, in fact, correct. This means that the second format and install should have worked, as well. Leaving out the possibility that the first was a repair install and also of some misconfiguration of the speaker connection, we are left with "the sound card died."
LOL
I called PackardBell helpcentre, they asked if I have some other version of window than XP, I told them i update my system to Win 7, they gave me link to download Realtek audio for Vista/win 7.
And it works perfect after next restart.
Thanks for the help, mate.
Regards
Where to start? I'm a amateur photographer and I want to start out in video
By James Wright in forum Newbie / General discussionsReplies: 14Last Post: 3rd Jul 2015, 14:12 -
The device USB 2861 device could not be opened
By Fabis94 in forum EditingReplies: 5Last Post: 20th Nov 2010, 13:40 -
HD Pvr 1212 - device is not connected - can't use device in arcsoft softwar
By yoda313 in forum Capturing and VCRReplies: 9Last Post: 16th Aug 2009, 17:22 -
Trying to locate a device in Device Manager
By alegator in forum ComputerReplies: 2Last Post: 13th May 2009, 10:53 -
Clonedvd error"invalid block start code"
By demonwarrior in forum Newbie / General discussionsReplies: 2Last Post: 6th Aug 2007, 05:01
