Hi all,
Ive just been getting a Sumvision Phoenix Premium 1080P Upscaling DVD Player cheap but seems ok. Thing is it will only let me fast forward or rewind certain avi files. I have an avi file which is xvid that i have split in 2 on the same disc the first half fast forwards and rewinds fine but when the second half starts i cannot fast forward or rewind it it says not possible at this time. Does anyone no why.
Thank you.
If the file was split perhaps it lost it's index, or the place on the dvd it is written to is damaged/faulty. Do you have the same issues on your PC?
Its fine on the PC, also i have tried a other avi file which is just on a disc on its own and that wont FF or RW.
Thank you. -
That means the program that was used to split/make the file(s) wasn't working properly.
An Xvid AVI normally has an index of all the keyframes at the end of the file. Players use that to locate the desired position when seeking, fast forwarding, or rewinding within the file. If the index is missing it's much harder to seek -- so many players won't even attempt to. DivFix walks through the video frame by frame to locate keyframes and rebuilds that index.
Next time you need to split a file try using VirtualDub in Video -> Direct Stream Copy mode. It should perform the operation properly.
AviDemux Fast Forward and Rewind
By MJS in forum EditingReplies: 2Last Post: 2nd Feb 2011, 07:16 -
Joining FLV videos -- playback problems with rewind/fast forward
By gumbygum in forum EditingReplies: 0Last Post: 30th May 2010, 16:32 -
How to Enable a Title for Fast Forward - Rewind?
By Nocturne in forum Authoring (DVD)Replies: 3Last Post: 28th Jun 2008, 00:46 -
Cannot seek (fast forward) through some WMV files
By MrFriendly in forum Newbie / General discussionsReplies: 4Last Post: 1st Nov 2007, 18:48 -
Video conversion of .rm to .avi or .mpeg with fast forward and rewind
By skv19 in forum Video ConversionReplies: 3Last Post: 23rd Jul 2007, 22:48
