Sometimes when I transfer old tapes every few seconds the Canopus ADVC-55 red light goes off for a brief moment and then comes back on, producing a stutter in the resulting video. I'm using a JVC SR-V101US and it's S-Video output. I've seen this across all 8 of my VCR's (all the same model) when transferring old tapes in bad condition. To get these tapes transferred I goto plan B, and use a startech USP cable using composite video.
What's the best way to keep a continuous sync signal between the JVC and the Canopus and eliminate this problem?
Thank you!
Brian
	The best way is to get a stand alone TBC to put in your capture chain between your VCR and the canopus box. A much cheaper alternative is to get a used Panasonic ES10 or ES15 DVD recorder on ebay, put it in between the VCR and the Canopus box (ie, just pass the video through the Panny). I'm pretty sure that it will provide continous sync, but you might want to let a few other comment on this before you run out and buy one. You might check out this thread - https://forum.videohelp.com/threads/319420-Who-uses-a-DVD-recorder-as-a-line-TBC-and-what-do-you-use It's focused more on the line TBC characteristics of ES10 and ES15 dvd recorders, but I think somewhere in there there may be a discussion of continuous sync also.
  Best UK PAL VHS / D-VHS machines for digitising old VHS tapesBy pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 10:21
  Losing HDMI signal to TVBy branhamr in forum Media Center PC / MediaCentersReplies: 1Last Post: 9th Apr 2011, 14:04
  DVHS VCR performance with EP speed tapes and VHS-C tapes?By NJRoadfan in forum RestorationReplies: 13Last Post: 8th Apr 2011, 21:36
  For VHS/S VHS tapes 10 - 20 years old what aspect ratio should I use 3:4 ?By fuzzblaster in forum Capturing and VCRReplies: 1Last Post: 10th Sep 2010, 17:27
  Copy inhibit signal prevents me from backing up my old VHS tapesBy ShaneJensen in forum Capturing and VCRReplies: 33Last Post: 28th Jun 2010, 21:39
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
