  1. hi, I'm new at this forum, and I'm not sure if this is the right place to post this.
    But, the thing is that I downloaded this movie, its in a bin file, and for comodity purpouses I extravted the mpeg file to rename it as an avi, that went fine. The thing is that I would like to extract the subtitles from de cd too, does any one knows what file has them? and what should I do to convert them in to a srt file? thank you
    Is it a SVCD? Check if it contains files like https://www.videohelp.com/svcd#struct . I don't know anything that can extract those subs.
  3. mmm, Not sure if its svcd, it has 4 folders in it, EXT, SEGMENT, MPEGAV and VCD. Ie xtracted the .DAT diel from the MPEGAV fodler, and rename it. But I was wondering If I could extract subs from somewhere there as well.
    It's a VCD and it does not contain any switchable subs.
  5. dammit, thanks anyway
