Closed Thread
Results 1 to 10 of 10
  1. Member SE14man's Avatar
    Jul 2005
    Queensland
    Hi,
    My ISP have provided me with an ip which doesn't change.
    I did ask my ISP if they could change the ip and they said no.
    I was wondering if there's a way to change the ip myself by changing the last 4 digits or whatever or change it to dynamic somehow?
    Or is this not possible?
    Thank you.
  2. Member SE14man's Avatar
    Jul 2005
    Queensland
    Fantastic!
    Thank you. Don't get too excited will ya?
    May 2001
    Why would you want to change?
    CHEERS GARRY
  4. Member SE14man's Avatar
    Jul 2005
    Queensland
    Well for some reason some site is denying me access and i have no idea why! I can only put it down to my ip being banned but even still i have no idea why this would have happened as i haven't been in anyway disruptive or abusive.
  5. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    do some research about how to use a proxy
  6. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    The likelihood is that the whole range or subnet associated with the ISP in question is being blocked by the website in question (due to someone or action totally unrelated to yourself). It has happened to me before.
    So i expect you are out of luck even if they could change the IP for you - so a proxy is the way forward.
    May 2001
    Go and get a vpn there a a few free ones about this would hide your Ip Adress
    CHEERS GARRY
  8. Member SE14man's Avatar
    Jul 2005
    Queensland
    Thanks so much fellas for your help!
    Really appreciate that!
    So much more helpful to me than just 'No' LOL!
    Cheers.
  9. I'm a MEGA Super Moderator Baldrick's Avatar
    No.
    Thread cleaned....you can continue discuss the no answer somewhere else.
