Hello
I have a dvd player mentioned above. The thing is that after exchanging the optical pickup it does not play any discs.
The motor spindles, the display shows "LOADING", the disc rotates for several seconds and then stops, and the display shows "0:00:00".
And that's that. And I cannot figure out what is the matter.
Does anyone have any idea what is going on?
Or perhaps where i could possibly get the service manual for the specified model?
That laser inside the pickup unit needs to find and track a spot on a disc that is thinner than one of your arm hairs...
I'm pretty sure a guy with a small screwdriver is going to be able to adjust that correctly.
But from what I've heard, the laser should be adjusted correctly in a company that makes it. Am I wrong?
Does the Sony BDP-S370 play DVD+R discs?
By MJ in forum DVD & Blu-ray PlayersReplies: 6Last Post: 4th Dec 2011, 04:38 -
Newbie needs help with getting burned discs to play on dvd player.
By Takeonelastbreath in forum Authoring (DVD)Replies: 1Last Post: 22nd Sep 2010, 15:02 -
Combined 2 discs into one, but disc won't play on dvd-player...
By StrobeLightEpileptic in forum Authoring (DVD)Replies: 5Last Post: 7th May 2009, 22:24 -
Will a Phillips DVDR3475/37 play DVD +R DL discs?
By c5vetman in forum DVD & Blu-ray RecordersReplies: 3Last Post: 30th Nov 2007, 12:47 -
DVD Recorded discs won't play on Laptop!! ):
By SteveMKIIDub in forum Software PlayingReplies: 11Last Post: 21st May 2007, 18:24
