Hi, I wanted to back up my blu ray films and wondered whether I could simply run an HDMI from my blu ray player into my laptop? Or, since my laptop doesn't have a blu ray drive would i need an external blu ray player or to fit an internal one?
just saving them on my harddrive was the plan or putting them on bd-r's
thanks -
The most reliable way would be to rip the bluray to your hd, then reburn it to bd-r. You would need a bd burner for your PC, a program to decode the original blu-ray (like anyDVD), and a program to burn the results to bd-r (like imgburn). If you wanted to shrink your originals to fit on less expensive bd-25s (assuming this is necessary), then an additional program like bdrebuilder would be needed as well.
You should be aware that if you need to compress the movies to fit a 25gb blu ray disk, you'll be running your cpu at full speed for many hours, overnight is not uncommon, depending on the speed of the computer. This continuous load on a laptop might cause overheating.
Desktops are more commonly used for this task.
Backing up Blu-ray with Hauppauge PVR
By Doc S in forum Blu-ray RippingReplies: 11Last Post: 20th Jun 2011, 19:16 -
Backing up blu-ray shortcut
By alucard2050 in forum Blu-ray RippingReplies: 4Last Post: 1st Dec 2009, 10:10 -
Is Backing up DATA in Blu Ray Recordable Discs Reliable?
By faramith in forum ComputerReplies: 9Last Post: 8th Oct 2009, 09:46 -
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 13:36 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 16:05
