I'm trying to use mkvpropedit in a batch file and need to switch the 'Disable header removal compression' option like in the GUI. What's the switch? I did check it in the GUI, but it doesn't pickup using the mkvpropedit.
Thanks Mike
Results 1 to 1 of 1
Prevent bumping old threads?
By lordsmurf in forum FeedbackReplies: 20Last Post: 8th Sep 2011, 01:35 -
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 19:40 -
Command-line command for fixing AVI?
By timur in forum ffmpegX general discussionReplies: 1Last Post: 23rd Sep 2009, 02:23 -
BD Rebuilder - Prevent resize
By gcrutcher in forum Newbie / General discussionsReplies: 5Last Post: 24th Mar 2009, 04:18 -
how do i prevent my dvd from being copied
By kareen_630 in forum Newbie / General discussionsReplies: 213Last Post: 6th Jan 2008, 08:16
