Over the course of the past 7 months or so I have closing on 200 gigs of internal HD space consumed and occupied by what I call aftermath/byproduct or were otherwise created during the post production process using that application.
I'm specifically reffering to:
a) media cache files
b) pro auto save files
c) pro preview files
and the like!
What I don't want to do is to intentionally delete files that I may have to regenerate once more because some of that data points/links to live, open projects that are not completed yet.
So, are any of these "safely" deletable so I can clear some hard drive space?
For example: is there any time lost, damage done or considerations if I did away with the media cache files?
What function do they have & should they be kept?
What I don't want to do is inadvertently spend more hours re-rendering each project and tying down my computer.
Yes if you don't intend to re-edit.
Premiere creates temp files when you "render the workspace" for a filter or transition. These are used to make a real time preview. When you encode to an output format and close the project, the temp files can be deleted, but if you reload the project, you will need to re-render the timeline before you can preview again.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
New "editing box", need advice on best use of multiple video cards.
By jaybird in forum Newbie / General discussionsReplies: 0Last Post: 10th Apr 2011, 22:16 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
How to fix "twitchy' or "jerky" .asf files.
By bbanderic in forum Video ConversionReplies: 2Last Post: 21st Sep 2007, 18:48 -
Problem "Full processing mode" in VirtualDub
By jonaskarlsson in forum AudioReplies: 11Last Post: 11th Aug 2007, 22:30 -
Why do I have 2 files? "Movie Clip" and "M2V File"
By tygger in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jun 2007, 22:55
