Hi all, I'd really appreciate your help on what I'm sure is a pretty simple task for you techies
I run a small non-profit music organization and someone made a DVD of our recent performance. The DVD is not copyrighted. I want to be able to rip the DVD by chapter and convert to smaller mpegs (to eventually use as marketing collateral on our website).
The files on the DVD, which I've copied to my hard drive are as follows:
video_ts.bup
vts_01_0.bup
video_ts.ifo
vts_01_0.ifo
video_ts.vob
vts_01_1.vob
vts_01_2.vob
vts_01_3.vob
vts_01_4.vob
Any help on how to extract and convert these into mpegs would be much appreciated!
If you can find the old DVDDecrypter program you can use it to rip by IFO and extract chapter by chapter. Other programs may be able to do this as well, but I only know that DVDDecrypter can do it. Note that this program is hard to find because the author was sued and forced to surrender his source code as part of a settlement, so you may have to look for it on Bit Torrent sites to find it. Note that you will need to play with the settings on DVDDecrypter as the default settings for IFO ripping won't do what you want. If no one suggests another way and you are able to find DVDDecrypter, look for a guide on how to use it.
DVDFab HD Decrypter might be able to rip by chapters and you can find it easily, but I don't know as I've never used it for anything but ripping an entire disc. -
DVDDecrypter
IFO Mode
File Splitting - BY CHAPTER(under settings)
That's if the DVD was authored by with chapter markers between songs. -
With it already on the hard drive open the IFO for the songs (the VTS_01_0.IFO) in PGCDemux. Tick 'Single Cell' (aka chapter). Demux it how you want, probably by 'Creating a PGC VOB' in the 'Options' area. The result will be the chapters demuxed as playable VOB files. If you need MPG, then use VOB2MPEG on them.
https://www.videohelp.com/tools/PgcDemux
Want to keep chapter markers with Vob2MPG in single mpeg
By Pontyac in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 8th Jan 2010, 13:14 -
New Website - DVD Chapter
By donaldallen in forum Latest Video NewsReplies: 17Last Post: 14th Jan 2009, 19:05 -
GUI for dvdauthor - How to make chapter thumbnails run the chapter video
By deco81 in forum Authoring (DVD)Replies: 4Last Post: 15th Dec 2008, 12:51 -
DVD chapter points
By Supreme2k in forum Off topicReplies: 3Last Post: 26th Oct 2007, 11:39 -
DVD Chapter Question.
By firewaterjoyride in forum DVD RippingReplies: 2Last Post: 19th Aug 2007, 00:05
