Hello,
I have a video clip and I want to adjust the brightness and contrast of the clip but with the bottom left corner being more adjusted than the top right (which will have no adjustment). This is to compensate for some lighting where it's much darker in one corner than the other. I'm using Adobe Premiere CS5. I don't have After Effects. (I do have photoshop and I tried to create an alpha channel mask (dark in one corner to light in the other) and I brought that image in, but I don't really know what to do with it now - can't see any way to apply that mask to anything or even know if that was a pointless step. What I considered doing was having a copy of the same video clip and adjusting that so it's brighter and more contrasty and then have some kind of mask or way of allowing me to make part of one clip transparent and the rest less so. Am I missing a simple trick here? I feel like there must be some way to fine tune things so that i'm not just changing the whole screen at once.
The search term you want to use is "Track Matte" . There should be dozens of tutorials on google, and instructions in the help pdf. If you're still stuck after watching the tutorials, don't be afraid to ask
Changing source clip in Adobe premiere CS4
By Flakture in forum EditingReplies: 0Last Post: 14th Feb 2011, 03:47 -
Lowering contrast in H264 file
By carlmart in forum Video ConversionReplies: 13Last Post: 19th Jun 2010, 09:33 -
Gamma vs Contrast
By CSULB71 in forum ComputerReplies: 9Last Post: 30th Apr 2010, 10:38 -
Contrast of subtitles
By Jomapil in forum SubtitleReplies: 6Last Post: 11th Nov 2008, 07:44 -
Dyamic Contrast Ratio
By snadge in forum DVB / IPTVReplies: 2Last Post: 29th Feb 2008, 20:44
