ripped dvd with dvd decrypter , ran them through dvd2avi, then encoded with tmpgenc (vfapi pluggin enabled) .All vobs processed fine bar 1, after encoding with tmpgenc, I got a completly different audio (like a documentary of the film sequence) . now ive heard that these vobs can be dual layered??, but is there any way to encode these and keep the original audio .it would save so much hassle forgot to mention that i checked the vob with power dvd , and the audio was fine before encoding
All VOB's contain all the audio soundtracks, what you need to do is change the soundtrack number in DVD2AVI before you save the project, that way it will create the correct WAV file for you.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
My pleasure, glad to be of help if I was !
Best Regards,
Sefy Levy,
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 06:36 -
additional audio decoder needed to play this soundtrack-Dolby AC3 Audio
By tbone1209 in forum AudioReplies: 6Last Post: 19th Jun 2011, 20:58 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 01:29 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 04:12 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 01:19
