  1. I have problems playing some HD mkv movies thru USB on my TV (sound dropuot every few seconds). The movies play fine on the PC. I successfully fixed this issue in one mkv file by extracting audio track using MKVextractGUI2, reencoding AC3 track using BeHappy (Aften AC3 CBR @ 448kbps profile), stretching it along the reencoding process to the video track size and then muxing it using mkvmerge.
    I tried similar process with another mkv file with TV sound issue. Its audio track is AC3 CBR 384 Kbps, 6 channels, 48 KHz, 16bit. When I demux it to separate AC3 file using MKVextractGui2, duration of the track is 5914208ms, duration of the videotrack is 6134957ms. Then I reencode it as described above to fit movie duration and mux it to the movie. When I play the movie, sound is in sinc in the very beginning and in the very end. Along the movie it's out of the sync. In some parts the sound is before video in others vice versa. What the heck?
    (I tried another approach too. I muxed extracted audio track (not the reencoded one) back to the video using mkvmerge. Without any audio stretching parameters in mkvmerge audio ends before video (logical, as its lenght is shorter). So I set audio stretching option in mkvmerge to fit video size. And guess what, resulting movie has similar sync issue, begginnig and end is fine, in the middle out of sync. Any ideas?)
    I'm quite newbie to this, maybe I'm missing something obvious...
    Apr 2004
    Miskatonic U
    My guess is that the overall bitrate is too high for your TV to either process smoothly, or to load form the USB. In the first case, just lowering the bitrate of the audio appears to have been enough, however if the audio is already encoded with a low bitrate - and 384 kbps is relatively low for HD - then encoding it at a higher bitrate won't solve your problem.
    You are also doing something very wrong if you are having to stretch the audio after simply demuxing. If the audio played in sync before demuxing, demuxing should not have caused such large run time discrepancies.
    Can I suggest a simpler process ? Download Xvid4PSP 5.37, load up your MKV file, keep video to Copy and re-encode your audio only (if that is what you want to do), selecting MKV as the output container. The process should only take a few minutes, and you shouldn't have any of these hassles.
    It may also be worthwhile posting a mediainfo of the problem file before you screw with it.
    Read my blog here.
  3. In both cases I reencoded from lower to higher bitrate. So bitrate has nothing to do with it. I was able to play movies with higher bitrates via same USB device. First movie that worked after encoding has slower bitrate (384) before encoding and higher (448) after encoding.
    As for shorter duration of the audio stream after demuxing - my guess is that this audio stream (in my native language) someone custom-added to the movie and was not originally part of it. My explanation to dropouts when playing on the TV is, that shorter audio stream was stretched along muxing process by adding "empty space" (my laic interpretation). This "empty space" is handled correctly by the PC, but causes TV drop out once in few seconds. Looks like tv cannot handle smoothly distributed "empty space" and "plays it" as whole every few seconds and this is hearable as about half second drop out. This theory I verified with first movie in which I reencoded audio stream to have same duration as video so no "empty space" had to be added during muxing to stretch the audio stream. This same works with second movie, there are no sound dropouts during playback, but theres out of sync issue I cannot understand.
    Also remember when I do no reencoding with demuxed stream and simply mux it back to the movie with stretch option in mkvmerge, dropouts remain and in addition there are sync issues. So reencoding is not the problem here.
    I tried xvid4psp as you suggested with no success. First used "copy" method for both audio and video streams. Then tried "copy" method for video and reencoded audio to AC3 448kbps. In both cases audio was faster than video and ended sooner leaving rest of movie silent.
  4. Here's media info of original movie with problematic audio stream Audio #1 (Audio #2 works ok):
    General
    Count : 270
    Count of stream of this kind : 1
    Kind of stream : General
    Stream identifier : 0
    Unique ID : 215526122828217629614608937766516579299
    Unique ID : 215526122828217629614608937766516579299 (0xA224D245A61023EBB8210CC5F1825BE3)
    Count of video streams : 1
    Count of audio streams : 2
    Count of text streams : 2
    Video_Format_List : AVC
    Video_Format_WithHint_List : AVC
    Codecs Video : AVC
    Video_Language_List : English
    Audio_Format_List : AC-3 / DTS
    Audio_Format_WithHint_List : AC-3 / DTS
    Audio codecs : AC3 / DTS
    Audio_Language_List : Czech / English
    Text_Format_List : UTF-8 / UTF-8
    Text_Format_WithHint_List : UTF-8 / UTF-8
    Text codecs : UTF-8 / UTF-8
    Text_Language_List : Czech / Czech
    Complete name :movie.mkv
    Folder name :
    File name : movie
    File extension : mkv
    Format : Matroska
    Format : Matroska
    Format/Url : http://packs.matroska.org/
    Format/Extensions usually used : mkv mka mks
    Commercial name : Matroska
    Codec : Matroska
    Codec : Matroska
    Codec/Url : http://packs.matroska.org/
    Codec/Extensions usually used : mkv mka mks
    File size : 9632030148
    File size : 8.97 GiB
    File size : 9 GiB
    File size : 9.0 GiB
    File size : 8.971 GiB
    Duration : 6134957
    Duration : 1h 42mn
    Duration : 1h 42mn 14s 957ms
    Duration : 1h 42mn
    Duration : 01:42:14.957
    Overall bit rate : 12560192
    Overall bit rate : 12.6 Mbps
    Stream size : 191663488
    Stream size : 183 MiB (2%)
    Stream size : 182.8 MiB
    Proportion of this stream : 0.01990
    Encoded date : UTC 2008-11-10 09:40:31
    File creation date : UTC 2011-01-03 16:17:50.229
    File creation date (local) : 2011-01-03 17:17:50.229
    File last modification date : UTC 2008-11-10 09:49:48.984
    File last modification date (loc : 2008-11-10 10:49:48.984
    Writing application : mkvmerge v2.2.0 ('Turn It On Again') built on Mar 4 2008 12:58:26
    Writing library : libebml v0.7.7 + libmatroska v0.8.1
    Video
    Count : 192
    Kind of stream : Video
    Unique ID : 1
    Format : AVC
    Format/Url : http://developers.videolan.org/x264.html
    Commercial name : AVC
    Format profile : High@L4.1
    Format settings : CABAC / 5 Ref Frames
    Format settings, CABAC : Yes
    Format settings, ReFrames : 5
    Format settings, ReFrames : 5 frames
    Internet media type : video/H264
    Codec ID : V_MPEG4/ISO/AVC
    Codec ID/Url : http://ffdshow-tryout.sourceforge.net/
    Codec : V_MPEG4/ISO/AVC
    Codec : AVC
    Codec/Family : AVC
    Codec/Info : Advanced Video Codec
    Codec/Url : http://ffdshow-tryout.sourceforge.net/
    Codec profile : High@L4.1
    Codec settings : CABAC / 5 Ref Frames
    Codec settings, CABAC : Yes
    Codec_Settings_RefFrames : 5
    Duration : 6134968
    Duration : 1h 42mn
    Duration : 1h 42mn 14s 968ms
    Duration : 1h 42mn
    Duration : 01:42:14.968
    Bit rate : 10676000
    Bit rate : 10.7 Mbps
    Width : 1920
    Width : 1 920 pixels
    Height : 800
    Height : 800 pixels
    Pixel aspect ratio : 1.000
    Display aspect ratio : 2.400
    Display aspect ratio : 2.40:1
    Frame rate : 23.976
    Frame rate : 23.976 fps
    Frame count : 147092
    Resolution : 8
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8
    Bit depth : 8 bits
    Scan type : Progressive
    Interlacement : PPF
    Interlacement : Progressive
    Bits/(Pixel*Frame) : 0.290
    Delay : 0
    Delay : 00:00:00.000
    Delay, origin : Container
    Stream size : 7988107308
    Stream size : 7.44 GiB (83%)
    Stream size : 7 GiB
    Stream size : 7.4 GiB
    Stream size : 7.440 GiB
    Proportion of this stream : 0.82933
    Writing library : x264 - core 65 r999 cc51047
    Writing library : x264 core 65 r999 cc51047
    Writing library/Name : x264
    Writing library/Version : core 65 r999 cc51047
    Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=12 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=10676 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
    Language : en
    Language : English
    Language : English
    Language : en
    Language : eng
    Language : en
    Audio #1
    Count : 173
    Count of stream of this kind : 2
    Kind of stream : Audio
    Stream identifier : 1
    Unique ID : 1547904672
    Format : AC-3
    Format/Info : Audio Coding 3
    Commercial name : AC-3
    Codec ID : A_AC3
    Codec : AC3
    Codec : AC3
    Codec/Family : AC3
    Codec/Info : Dolby AC3
    Duration : 6134957
    Duration : 1h 42mn
    Duration : 1h 42mn
    Bit rate mode : CBR
    Bit rate mode : Constant
    Bit rate : 384000
    Bit rate : 384 Kbps
    Channel(s) : 6
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Channel positions : 3/2/0.1
    Sampling rate : 48000
    Sampling rate : 48.0 KHz
    Samples count : 294477936
    Resolution : 16
    Resolution : 16 bits
    Bit depth : 16
    Bit depth : 16 bits
    Compression mode : Lossy
    Delay : 0
    Delay relative to video : 0
    Video0 delay : 0
    Stream size : 294477936
    Stream size : 281 MiB (3%)
    Stream size : 280.8 MiB
    Proportion of this stream : 0.03057
    Language : cs
    Language : Czech
    Language : Czech
    Language : cs
    Language : ces
    Language : cs
    dialnorm : -30
    dialnorm/String : -30 dB
    compr : 5.46
    compr/String : 5.46 dB
    bsid : 8
    dialnorm_Average : -30
    dialnorm_Average/String : -30 dB
    dialnorm_Minimum : -30
    dialnorm_Minimum/String : -30 dB
    dialnorm_Maximum : -30
    dialnorm_Maximum/String : -30 dB
    dialnorm_Count : 2
    compr_Average : 5.46
    compr_Average/String : 5.46 dB
    compr_Minimum : 5.46
    compr_Minimum/String : 5.46 dB
    compr_Maximum : 5.46
    compr_Maximum/String : 5.46 dB
    compr_Count : 2
    Audio #2
    Count : 154
    Stream identifier : 2
    Unique ID : 71794582
    Format : DTS
    Format/Info : Digital Theater Systems
    Commercial name : DTS
    Codec ID : A_DTS
    Codec : DTS
    Codec : DTS
    Codec/Family : DTS
    Duration : 6134957
    Duration : 1h 42mn
    Duration : 1h 42mn
    Bit rate mode : CBR
    Bit rate : 1509750
    Bit rate : 1 510 Kbps
    Channel(s) : 6
    Resolution : 24
    Resolution : 24 bits
    Bit depth : 24
    Bit depth : 24 bits
    Delay : 0
    Video0 delay : 0
    Stream size : 1157781416
    Stream size : 1.08 GiB (12%)
    Stream size : 1 GiB
    Stream size : 1.1 GiB
    Stream size : 1.078 GiB
    Proportion of this stream : 0.12020
    Language : en
    Language : English
    Language : English
    Language : en
    Language : eng
    Language : en
  5. Here's media info of the AC3 stream after demuxing:
    Audio
    Count : 173
    Format : AC-3
    Codec : AC3
    Codec : AC3
    Duration : 5914208
    Duration : 1h 38mn
    Duration : 1h 38mn 34s 208ms
    Duration : 1h 38mn
    Duration : 01:38:34.208
    Bit rate mode : CBR
    Bit rate : 384000
    Bit rate : 384 Kbps
    Channel(s) : 6
    Samples count : 283881984
    Frame count : 184819
    Resolution : 16
    Bit depth : 16
    Bit depth : 16 bits
    Stream size : 283881984
    Stream size : 271 MiB (100%)
    Stream size : 270.7 MiB
    Proportion of this stream : 1.00000
    dialnorm : -30
    compr : 5.46
    bsid : 8
    dialnorm_Count : 32
    compr_Average : 5.73
    compr_Average/String : 5.73 dB
    compr_Maximum : 5.74
    compr_Maximum/String : 5.74 dB
    compr_Count : 32
  6. Here's media info of the AC3 stream after reencoding:
    Audio
    Count : 164
    Format : AC-3
    Codec : AC3
    Codec : AC3
    Duration : 6134976
    Duration : 1h 42mn
    Duration : 1h 42mn 14s 976ms
    Duration : 1h 42mn
    Duration : 01:42:14.976
    Bit rate mode : CBR
    Bit rate : 448000
    Bit rate : 448 Kbps
    Channel(s) : 6
    Samples count : 294478848
    Frame count : 191718
    Resolution : 16
    Bit depth : 16
    Bit depth : 16 bits
    Stream size : 343558656
    Stream size : 328 MiB (100%)
    Stream size : 327.6 MiB
    dialnorm : -31
    dialnorm/String : -31 dB
    bsid : 8
    dialnorm_Average : -31
    dialnorm_Average/String : -31 dB
    dialnorm_Minimum : -31
    dialnorm_Minimum/String : -31 dB
    dialnorm_Maximum : -31
    dialnorm_Maximum/String : -31 dB
    dialnorm_Count : 32
  7. Finally movie after muxing reencoded stream back:
    General
    Count : 270
    Unique ID : 207110848612135334496200149260253583138
    Unique ID : 207110848612135334496200149260253583138 (0x9BD0193846B37CD78C593E0864F8D722)
    Count of audio streams : 1
    Codecs Video : AVC
    Audio codecs : AC3
    Complete name : movie2.mkv
    Folder name :
    File name : movie2
    Format : Matroska
    Format : Matroska
    Codec : Matroska
    Codec : Matroska
    File size : 8531451080
    File size : 7.95 GiB
    File size : 8 GiB
    File size : 7.9 GiB
    File size : 7.946 GiB
    Duration : 6134976
    Duration : 1h 42mn
    Duration : 1h 42mn
    Overall bit rate : 11125000
    Overall bit rate : 11.1 Mbps
    Stream size : 169786411
    Stream size : 162 MiB (2%)
    Stream size : 161.9 MiB
    Encoded date : UTC 2011-01-06 14:24:26
    File creation date : UTC 2011-01-06 14:24:26.481
    File creation date (local) : 2011-01-06 15:24:26.481
    File last modification date : UTC 2011-01-06 14:27:27.578
    File last modification date (loc : 2011-01-06 15:27:27.578
    Writing application : mkvmerge v4.4.0 ('Die Wiederkehr') built on Oct 31 2010 21:52:48
    Writing library : libebml v1.0.0 + libmatroska v1.0.0
    Video
    Count : 192
    Unique ID : 1
    Format : AVC
    Muxing mode : Header stripping
    Codec : AVC
    Codec/Family : AVC
    Duration : 6134968
    Duration : 1h 42mn
    Duration : 1h 42mn
    Bit rate : 10676000
    Width : 1920
    Height : 800
    Height : 800 pixels
    Frame rate : 23.976
    Resolution : 8
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Color space : YUV
    Bit depth : 8
    Bit depth : 8 bits
    Interlacement : PPF
    Delay : 0
    Stream size : 8018106013
    Stream size : 7.47 GiB (94%)
    Stream size : 7 GiB
    Stream size : 7.5 GiB
    Stream size : 7.467 GiB
    Proportion of this stream : 0.93983
    Language : en
    Language : English
    Language : English
    Language : en
    Language : eng
    Language : en
    Audio
    Count : 164
    Unique ID : 1981684666
    Format : AC-3
    Codec ID : A_AC3
    Codec : AC3
    Codec : AC3
    Codec/Family : AC3
    Duration : 6134976
    Duration : 1h 42mn
    Duration : 1h 42mn
    Bit rate mode : CBR
    Bit rate : 448000
    Bit rate : 448 Kbps
    Channel(s) : 6
    Resolution : 16
    Bit depth : 16
    Bit depth : 16 bits
    Delay : 0
    Video0 delay : 0
    Stream size : 328 MiB (4%)
    Proportion of this stream : 0.04027
    Language : cs
    Language : Czech
    Language : Czech
    Language : cs
    Language : ces
    Language : cs
    dialnorm : -31
    bsid : 8
    dialnorm_Count : 2
