Hi
this is not my first post on this topic
While when I have .iso files it is very easy for me to create a dvd through imgburn, I am not able to do it when I have 2 folders (one audio_TS empty and the other one Video_TS with files in different format, .ifo. vob etc)
what is the best sw to use ( I would like to create a dvd with chapters etc), alternative to imgburn or imgburn in an effective way?
thanks/Fabio
				Results 1 to 10 of 10
	Imgburn.
 Start Imgburn. Select Write Files/Folders to Disc. Click on the Browse for a Folder icon and select your Video_TS folder. Imgburn will know this is a DVD and set everything up accordingly. Now click Burn.
 Note : Imgburn only burns. It does not do chapters or menus. For that you need an authoring tool. After authoring you will be back to having a video_ts folder, which you can then burn with Imgburn.Read my blog here.
	I don't understand your question. Perhaps you can rephrase in plain English, without abbreviations, and go into a little more detail about your problem. What does "sw" stand for, etc.
	If you are not using the graphical interface - Ez-Mode Picker - select 'Build' from the mode menu.
 Click on the little folder icon (third down) 'browse for a folder'. Select the 'Audio_TS' folder (optional) and the 'Video_TS' folder you which to burn - select OK after each select and then burn the disk.
	THANKS
 CAN i USE IMGBURN BEFORE UNZIPPING THE FILE?
 LET ME CLARIFY: i HAVE AN ISO FILE ZIPPED (.RAR); WHEN i UNZIP IT i HAVE THE 2 FOLDERS ABOVE ( AUDIO AND VIDEO_TS)
 I WONDER IF I CAN BROWSE WITH IMGBURN (OPTION "WRITE IMAGE FILE TO DISC") DIRECTLY THE VIDEOFILE ZIPPED (IN ISO FORMAT)
 JUST A THOUGHT....
 THANKS
	Yes, but you'll end up with a disk with a RAR file on it - probbaly not what you really want.
 1) Extract everything from the RAR file. Do you now have...
 2A) a single file with type ISO - in IMGBURN use "Write Image File To Disk" & pick the ISO file
 2B) a folder called VIDEO_TS (and maybe an AUDIO_TS, but not essential) - in IMGBURN use "Write File/Folders To Disk" and pick the VIDEO_TS folder
 Trevor
	But there is even more confusion.
 If your original file ends with .iso it is NOT an rar file it is an image file which CAN be burnt direct to a disk with imgburn.
 You CAN extract the contents of an .iso file with a program like winrar but there is little point to doing that since it just adds more work when you simply want to burn the file(s) back to disk.
  Imgburn problem....HelpBy tyder26 in forum Authoring (DVD)Replies: 5Last Post: 12th Jul 2011, 18:59
  ImgBurn Problem!!! Help!!By dupt in forum DVD & Blu-ray WritersReplies: 8Last Post: 5th Aug 2010, 05:59
  problem with ImgBurnBy rcguy1 in forum DVD RippingReplies: 7Last Post: 4th Nov 2007, 13:18
  ImgBurn is this my ProblemBy Gunewbie in forum ComputerReplies: 3Last Post: 4th Oct 2007, 01:15
  ImgBurn ProblemBy myck3m in forum Authoring (DVD)Replies: 3Last Post: 20th Jun 2007, 11:42
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
