After searching Im still dont know how I can edit the length down of a DVD9 to DVD5 size. The DVD is NTSC and has LPCM and DTS, I've tried different authoring softs but none recognize the DTS audio component. If DVD-lab will do this Im unable to find a tutorial which specifically explains the encoders to a noob. Please provide me some direction.
EDIT: I would like to keep both audio's intact, but reduce main movie length.
Results 1 to 14 of 14
Samsung HMX-H106SN/XAC HD Camcorder -
I have quite a few DVD9 that I am able to backup to two DVD5, one with DTS, and one with LPCM, with dvdshrink.
I am going to assume you mean compress a dvd9 (dual layer) down to a dvd5 (single layer dvdr) and not edit the length of the movie/video...
As SingSing already stated, DvdShrink, or if you want a bit better video quality, Dvd Rebuilder.
Dvd-Lab is just an Authoring program, is does not "shrink", "Transcode" or "Re-convert" video down from a dvd9 to a dvd5.
If your original dvd is only 5.2GB then dvd shrink will probably suffice for the job, if you only want the main movie/video then you may not have to shrink it at all ?
I have used both the above mentioned programs to fit a dvd9 with DD 2.0, DD 5.1 & DTS 5.1 audio tracks from much larger dvd9's to single layer dvdr's. -
With DVD shrink, doesnt it compress the DVD? I'd like to edit out content to make it smaller with smooth transitions etc.
Thank-you folks for your guidance, I'll look into these.
Hello again, tried DVD rebuilder and am sure DVD shrink isn't what I need because even with deleting extras, its still over DVD5 size. I want to edit out main movie content to make it smaller with smooth transitions, fade outs etc. Possible?
It's not going to happen and it will not save enough space trying to change or re-encode transitions or fade ins/outs to make the effort worth while, you will either have to use dual layer dvdr's, transcode it (dvdshrink) or re-encode it (dvdrbuilder) to make it fit on a SL dvdr.
Even in "re-author" mode with dvdshrink if it is still to large to fit on a SL dvdr you are going to have to do 1 of the 2 suggestions mentioned previously, period!
Transcode or re-encode.....
Now if you want to cut out scenes or 10, 20 minutes, of the entire video then it is possible........ -
Lucky for you that you admitted upfront that you're a noob, because your questions are a little...exasperating.
I'd venture to say most veteran members here must be thinking of the work involved in what you propose. And for what? A DVD backup? For goodness sake, just spend an extra fifty cents and put it on a dual-layer DVD, no re-encoding at all, and be done with it.Pull! Bang! Darn! -
Again, dvdshrink, but what's the point of not re-encoding ?
To save some space by cutting out 20 minutes of a film/movie instead of re-encoding it and odd's are you nor anyone else will ever be able to tell the difference considering your original is barely over the size of a dvd5
Time for a fork, cause this is done!!
LOL!!! -
Ditch the DTS and maybe you can do it. Womble Mpeg Video Wizard can edit your files (you may have to demux first) but I don't think it will do DTS. VideoRedo probably will do DTS, but it won't do transitions.
DVD Rebuilder will re-encode your file to DVD5 size, if you use it correctly, however if you insist on DTS audio you will take a quality hit - DTS needs a lot of space.Read my blog here.
No dts-hd after bd rebuilding
By Gizzie666 in forum Blu-ray RippingReplies: 2Last Post: 10th Apr 2010, 08:45 -
MKV to dvd while keeping the dts audio intact
By Loonatik in forum Authoring (DVD)Replies: 13Last Post: 30th Mar 2010, 10:41 -
help gettinng .m2ts with dts to play on ps3 with the dts intact. got close
By jayjay139 in forum Blu-ray RippingReplies: 0Last Post: 12th Mar 2010, 12:10 -
HD PVR HAUPPAUGE probs editing any of the formats and keeping audio intact
By chuffy in forum EditingReplies: 2Last Post: 5th Sep 2009, 17:32 -
convert flac to mp3 while keeping all id tags intact
By lordhutt in forum ComputerReplies: 2Last Post: 13th Jul 2007, 22:56
