I'm fairly new at the demuxing process, but I've been having issues singling out the dts-hd master audio track from the m2ts file within the bluray stream folder. I use tsmuxer 1.10.6 and leave the downconvert dts-hd to dts box unchecked. After the demuxing process, the audio file has a .dts extension rather than .dtshd. Mediainfo shows two bitrates, one for Master and one for core. However when playing the file from mpc, it plays only the core at 1509 kbps.
- 4 questions:
Any help would be greatly appreciated
- Does the .dts file exension vs .dtshd even matter?
- Shouldn't the master audio be playing closer to 2500 kbps?
- Do I need to use other software to take advantage of the master audio?
- If I remux audio & video files back into bluray structure (BDMV/Certificate) will my receiver play the master audio (it does support it and I'm using HDMI)?
Results 1 to 1 of 1
Transcode 7.1 DTS-Master Audio to 7.1 L-PCM (.wav/.aiff)
By nateo200 in forum Blu-ray RippingReplies: 10Last Post: 27th Apr 2012, 15:57 -
Blu-ray + DTS-HD authoring with tsMuxeR
By Zerrax in forum Authoring (Blu-ray)Replies: 1Last Post: 11th Nov 2011, 18:30 -
Extracting DTS-HD track with tsmuxer
By rantonio in forum Blu-ray RippingReplies: 3Last Post: 18th Mar 2011, 08:23 -
DTS 15xx kbps to DTS 768 kbps and tsMuxeR question.
By Jared_ in forum AudioReplies: 0Last Post: 1st Jun 2009, 09:46 -
Issue with TSMuxer and DTS audio
By ma2kp in forum Video ConversionReplies: 2Last Post: 25th Oct 2008, 13:16
