  1. Member Innershield's Avatar
    Jul 2001
    Akron, Ohio
    Everytime I close a window and reopen it, windows always reorganizes my view setting. It started out being in just one folder for a long time, now it is doing it in all of them. And I do have the "remember folder view settings" box checked. Must be in the registry setting but I dont know which. Windows XP
  2. Member Innershield's Avatar
    Jul 2001
    Akron, Ohio
    Does anybody know how to fix this?
    Mar 2002
    Florida
    try tweakxp.com?? or other windowsannoyances.org, etc sites
  4. Member Innershield's Avatar
    Jul 2001
    Akron, Ohio
    already looked there but thanks
  5. Chris S ChrisX's Avatar
    Jan 2002
    Some dude from Sydney
    TO INNERSHIELD
    I think you should look in Microsoft's Support Knowledge Base:
    http://search.support.microsoft.com/kb/c.asp?fr=0&SD=GN&LN=EN-US
    I have found one titled: "The View Setting of the Current Selected Folder Is Not Applied to Another Open Folder" (Q307116)
    http://support.microsoft.com/search/preview.aspx?scid=kb;en-us;Q307116
    I don't quite know whether this will help you? However, I do think you should reset the "all folders" setting in WinXP. In the folder, go to "Tools" then "Folder Options" then "view" then click "Reset all folders". Do you try this?
  6. Member Innershield's Avatar
    Jul 2001
    Akron, Ohio
    That didn't work either, I'll try to keep looking
