Hello all.
I have Sony Vegas Movie Studio 9. I have edited from an mgeg2 a one minute project together. I now have the same file of the source mpeg2 that I edited with as an h264 quicktime file, at much higher quality, from the original source.
What I want to do is create a much better quality video file, with the exact same edits on the h264 as the mpeg2 I originaly edited on.
Is there a way to either tell exactly at what time in that mpeg 2 file each edit was made (example, to tell that a specific edit started at 12 minutes 2 seconds and 9 frames, and ended at 12 minutes 7 seconds and 12 frames, to try to match the h264 file exactly with the mpeg2 file), OR, is there a way I can substitute the h264 file for the mpeg 2 file, and keep the same edit points?
Thanks in advance.
Only method is to load the original in the first video line ... and a second video line below and load the edited version into there ... scan frame by frame and detect changes ... the first change is the start marker 1 ... moving forward and detect change again ... this is end marker of 1 ... this is the first edit point section.
For this I would use a copy of the original file ... keep the original as an untouched backup.
When you edited the file and set sony off with the encoding process certain frames (or number of) would have had additional encoding to join segments ... especially if transitions where used ... it might be easier to split the original (copy) at this point so you can align the second section with the edited file ... matching frames aligned ... then repeat above ... split again ... repeat.
In the end you'll have segmented the original (copy) and the splits indicate where edit's had occurred
A long process ... which is why the program has a feature for backing up projects
I'm not sure what BJ's is saying, but in the pro version, you just right click and "replace" . I'm not sure if it's the same in the studio version. This will swap out the old asset with the new one, with edits preserved. If you've used the same clip more than once, all instances of the old asset will be replaced by the new asset
As a side note, you can also copy just the attributes from one event to another.
Thanks everyone. Not long after I had posted the message I figured out I could do it with the "replace" command.
Thanks, though!
Video Artefact Problem - Sony vegas Movie Studio Platinum 9
By abeelandig in forum Video ConversionReplies: 5Last Post: 11th Jun 2011, 10:40 -
How to put 640x480 video in 1280x720 frame in Sony Vegas Movie Studio?
By vid83 in forum EditingReplies: 6Last Post: 10th Feb 2011, 22:47 -
How to edit overmodulated audio in sony vegas movie studio platinum 9
By floriday_girl in forum EditingReplies: 1Last Post: 13th Sep 2010, 08:59 -
How do I create a Timelapse video in Sony Vegas Movie Studio 7.0?
By Jflow in forum EditingReplies: 1Last Post: 5th Jun 2008, 21:06 -
Sony Vegas Movie Studio/DVD Architect Studio
By DJL82 in forum EditingReplies: 8Last Post: 1st Feb 2008, 15:14
